Okay guys, I'm sure this was outlined in the brake sticky but I couldn't quite piece together the info I wanted. I have a 2001 GP GTP, I have stock rear brakes and upgraded front brakes.
The fronts are broken down as follows:
Stock '01 GTP caliper
2001 Monte Carlo SS Braket
2001 Monte Carlo SS Rotor (303mm)
Stock '01 GTP pads
What I want to know is:
With my current brake setup, can I put the dual piston '06+ Impala calipers on without changing anything else?
And if not to the above question, will using '06+ Impala calipers with ,06+ Impala brackets, and '01 Monte SS rotors work? Will that system be compatible?
Of course, if I use the Impala calipers, I will be buying Impala pads as well.
Thanks for the help!
