Thread: Tuning components
Results 1 to 6 of 6
  1. #1 Tuning components
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Hey all, I've got components in the front with separate tweeters and 2 way cross overs in the rear deck all hooked up to a 4 channel amp and 1 sub hooked up to a mono block. My question is are components suppose to put out some bass? I tuned it by ear using Crutchfield website and they said tune it so you don't hear any bass from the fronts if you have a sub, now my sub hits hard n like it should, but some songs the bass sounds real tinny with the speakers... Any way to fix that? Thanks
  2. #2 Re: Tuning components
    Jul 2012
    Chicago
    I set my low pass for the mids at 80hz. You want them to put out some bass to help delocalize the sub.
    Doing some deadening on the door's outer door skin will help the mids low frequency response as well.
    What do you have for a head unit?
    -Carl
  3. #3 Re: Tuning components
    Sep 2015
    Seattle
    Yeah currently I don't have my filters on the HU on, just on the amps. I have an Alpine 153BT
  4. #4 Re: Tuning components
    Sep 2015
    Seattle
    It only gives me LPF for the sub tho..
  5. #5 Re: Tuning components
    Jul 2012
    Chicago
    Use the HU's filters instead of the amp's.
    Mine are set as follows:
    Tweets -> HPF @ 4khz with an 12db slope
    Mids -> HPF @ 80hz with a 12db slope
    -> LPF @ 4khz with a 12db slope
    Sub -> LPF @ 80hz with a 12db slope.
    -Carl
  6. #6 Re: Tuning components
    SE Level Member vredesbyrd's Avatar
    Aug 2014
    SK Canada
    I run no filter on my mids and just don't overpower them. Like nos said that helps localize the sound to the front ( so does a lower high pass). What size are the mids? Using a lower frequency for the subs helps too but you usually can't go below 80 unless u have big mids. IMO a highpass on your mids only helps for higher volume output by protecting the mids from over excursion.
    Sent from my GT-I9505G using Tapatalk
    02 GT. Transgo shift kit, stereo
  1. Replacing AC components
    By vertebrate in forum General Tech Discussion
    Last Post: 08-30-2012, 11:06 AM
  2. 6.5 components in front door
    By blakgtp in forum Audio, Security & Visual Electronics
    Last Post: 10-09-2011, 06:28 PM
  3. Interior Components
    By cowmilker08 in forum General Tech Discussion
    Last Post: 04-01-2009, 01:59 PM
  4. L67 components
    By straight_upprix05 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 08:01 PM
