Thread: subwoofer install
Results 1 to 11 of 11
  1. #1 subwoofer install
    Nov 2008
    Indiana
    I installed an aftermarket head unit and now im looking at installing a sub in the trunk with amp. My question is .. where is the easiest place to run the battery wire from under the hood to the trunk ? Do I need to drill a hole in the firewall or is there an access to run the wire through ? thanks for any help..
    2002 Grand Prix GTP
  2. #2 Re: subwoofer install
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    You can fish the power wire through one of the grommets on the firewall and then tuck it under the plastic molding all the way to the trunk. It's a tight fit in the grommet but it can be done. If I remember right, when I did it I used a piece of stiff metal coat hanger, stuck it through the grommet from the inside and then electrical taped the power wire to it (super tight) and pulled it through.
  3. #3 Re: subwoofer install
    i just ran some wires into the throttle cable grommet, they come out to the right of the console. you need to pull the rug back to get them.
  4. #4 Re: subwoofer install
    Nov 2008
    Indiana
    I asked too soon LOL.. I started looking and luckily the PO has already wired it for a sub . Saved me a bunch of time. Thanks for the replies though !!
    2002 Grand Prix GTP
  5. #5 Re: subwoofer install
    GXP Level Member
    Mar 2015
    Tomball
    What is a throttle cable grommet?
  6. #6 Re: subwoofer install
    Feb 2013
    Missouri
    Rubber piece the throttle cable goes through on the firewall to enter the engine bay.
  7. #7 Re: subwoofer install
    GXP Level Member
    Mar 2015
    Tomball
    What's a throttle cable....
  8. #8 Re: subwoofer install
    Quote Originally Posted by J57ltr View Post
    I know right?
  9. #9 Re: subwoofer install
    GXP Level Member
    Mar 2015
    Tomball
    I wish I had a throttle cable, need something so I can rev the engine from under the hood without getting the ole' lady out and taking 10 minutes to explain what I need her to do lol.
  10. #10 Re: subwoofer install
    Nov 2011
    NY
    Agreed, there are some things that should remain mechanical and less prone to failure, or as recently demonstrated, hacking! IC boards do have life spans as well and I'd be hard pressed to find a DBW still working in say 25 years. Let's see... Lolz
    sorry OP for going off topic...
  11. #11 Re: subwoofer install
    Nov 2008
    Indiana
    Its all good
  1. Anyone use a sound bar with no subwoofer or wireless subwoofer?
    By Silver2kgtp in forum Off Topic Discussion
    Last Post: 06-30-2013, 11:54 PM
  2. Subwoofer suggestions?
    By GTLGDP in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2012, 01:32 AM
  3. Subwoofer help....
    By Jordin in forum Audio, Security & Visual Electronics
    Last Post: 12-18-2011, 10:56 PM
  4. subwoofer box
    By grand2000prixgtp in forum Audio, Security & Visual Electronics
    Last Post: 12-14-2009, 09:21 PM
  5. Home Subwoofer in my GP?
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 05-19-2009, 01:11 PM
