Thread: wiring schematic for 3rd brake light
Results 1 to 20 of 21
  1. #1 wiring schematic for 3rd brake light
    i need the wiring schematics for the third brake light, both 12v power when the brake pedal's depressed as well as the ground wire. im trying to hook up an LED light for possibly when i get the wings west spoiler repainted and isntalled on the car. thansk in advance.
  2. #2 Re: wiring schematic for 3rd brake light
    Oklahoma
    Ummm, I'll see if I can dig it up and post..
  3. #3 Re: wiring schematic for 3rd brake light
    Oklahoma
    If this is not what you need, let me know and I'll see what I can dig up
  4. #4 Re: wiring schematic for 3rd brake light
    im guessing its the center high mounted stop lamp? if so it looks like black's the ground on one side and white's the other side thats 12v?
  5. #5 Re: wiring schematic for 3rd brake light
    Oklahoma
    Thats the way I read it. Its an orange wire from the fuse to the brake switch. The other side of the switch its white to a splice point 'S205', and it continues as white from there to the brake light, or the third brake light or the center high mounted brake like as they like to call it.
    Then on the other side of the bulb, its black. It goes to splice point 'S406', one of those two wires goes to chasis ground G302, then the other black wire goes to connector C400 on Pin A. From there it goes through a grommet 'P400' then to splice point S402. Im not sure what that is in the dotted lines unless is the dash turn signal bulb or something, but it changes wire color on the other side of that to Green and then goes through a couple of connectors to the turn siganal switch on the steering column.
    Now if you need the location of those splice points and grommets and connectors, just let me know, I believe I have the diagrams for that as well.
  6. #6 Re: wiring schematic for 3rd brake light
    yes please on the diagrams ^_^. last thing i want is see sparks ignite, and i know i'd need a multimeter b4 i go connecting and tapping wires lol
    edit.....looks like i'd want to finds G302 for the ground and C400 or S402 for the power wire(looks like it goes into the one tail light)
  7. #7 Re: wiring schematic for 3rd brake light
    Oklahoma
    Most of the splice information I have is in textual form rather than diagrams, so I'll give you this:
    S402
    (CKT 350) Rear lamp wiring harness, behind the right taillamp, approximately 4 cm (2 in) from the right tail/stop/turn signal lamp breakout
    G302
    (CKT 350) Right door sill, forward of the right front seat
    I didnt see in anything that I have that indicated the location of C400, but I'll keep looking and I did find something else that may be of assistance. I'll post it up as soon as I get it on my picture account.
  8. #8 Re: wiring schematic for 3rd brake light
    S402 is the 12v power correct? if so, the only other wire is a ground source, can i just ground the wire from the LED to a chassis bolt somewhere?
  9. #9 Re: wiring schematic for 3rd brake light
    Oklahoma
    Quote Originally Posted by fst View Post
    No, S402 is a ground splice. S205 is the 12v power source splice that is only active when the brake is used or more specifically, the brake switch activated.
  10. #10 Re: wiring schematic for 3rd brake light
    Oklahoma
    C400
    (6 cavities) Body wiring harness to the rear lamp wiring harness, behind the trim at the
    right rear corner of the rear compartment
  11. #11 Re: wiring schematic for 3rd brake light
    wha? wheres that exactly is the right rear compartment? lol why cant the schematics be easier T_T
  12. #12 Re: wiring schematic for 3rd brake light
    Oklahoma
    Maybe this will help a little too.
  13. #13 Re: wiring schematic for 3rd brake light
    so it looks like it need the white(S205) wire that goes out to somewhere and not the other white one that seems to just loop to the other one for the 12v power source. which leaves the ground wire/source, could i get away and just ground the ground wire from the Spoiler's LED?
  14. #14 Re: wiring schematic for 3rd brake light
    Oklahoma
    Well in reality you can ground the thing anywhere to the body of the car since the whole chasis is at ground potential. So as long as its a point that isnt covered by paint or something like that, then you can ground it anywhere. Then tap the white wire in the connector to the third brake light and you should be good to go.
    Now, that said, that LED brake light is probably not going to handle 12v very long, so make dang sure that there is some current limiting device that is part of the LED light you have.
  15. #15 Re: wiring schematic for 3rd brake light
    will i dunno if there is included? heres a pic of the LED 4th brake light im pondering up:
  16. #16 Re: wiring schematic for 3rd brake light
    Oklahoma
    I got a quick and easy solution for ya. Just pack that thing up and send it to me, LOL. I'll wire it in on my car and show you how it works and then you can get another and copy what I did.
    You are likely going to have to extend the wiring from the LED down into the trunk area and obviously make it long enough that it will not bind or anything like that when the trunk lid is open. But once you do that, you'll be able to ground it somewhere to the body/chasis in the trunk and then either connect the 12v source to the third brake light or even the tail lights for that matter.
    How you will pass the wiring from the spoiler to through the trunk lid Im not sure, I would assume that there is a hole or something that you could use. I would assume the LED brake light has some current limiting designed into it but I dont know that for sure. If its an aftermarket or factory set up from another vehicle or something, I would hope they have the current limiting built into it.
  17. #17 Re: wiring schematic for 3rd brake light
    yea i hope so too that theres a limter device somewhere in the LED setup. i was trying to sell it but i guess for what i wanted it for ppl passed on it so im gonna keep it
  18. #18 Re: wiring schematic for 3rd brake light
    Oklahoma
    I thought I seen that thing before. I wanted it but Im doing all I can to get out of debt and just a couple months from being there. Additionally, I wasnt sure how that sucker was going to mount up and how I would get the existing holes that are drilled, fixed.
  19. #19 Re: wiring schematic for 3rd brake light
    i hear ya on paying the bills/loans. i was planninng on selling the spoiler and trunk lid to make it easier, but apparently shipping would be a problem donw the road.
  20. #20 Re: wiring schematic for 3rd brake light
    Leland
    need schematics for o1 gtp took everything out of a 01 gtp that brother fliped and put it in a 97 se body head lights dont work when i press horn turn signal comes on does not blink it stays solid light i need HELP dont know what problum is
  1. 4th Brake Light (Under Decklid)
    By drunknmunky in forum How To Write-Ups/Tech Tips
    Last Post: 05-27-2011, 07:57 PM
  2. 3rd brake light decal
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 10-01-2008, 09:47 PM
  3. 4th Brake Light/Write Up
    By drunknmunky in forum Visual/Body Modifications
    Last Post: 07-26-2008, 06:37 PM
  4. parking brake light???
    By kingd44 in forum General Tech Discussion
    Last Post: 02-20-2008, 11:38 PM
