Thread: 2000 Grand Prix Bose wiring diagram, woofers work, 6x9's not turning on
Results 1 to 4 of 4
Xanthous 2000 Grand Prix Bose wiring... 01-10-2015, 06:04 PM
Slick2500 Re: 2000 Grand Prix Bose... 01-10-2015, 06:21 PM
Xanthous Re: 2000 Grand Prix Bose... 01-18-2015, 05:51 AM
Xanthous Re: 2000 Grand Prix Bose... 01-22-2015, 08:21 AM
  1. #1 2000 Grand Prix Bose wiring diagram, woofers work, 6x9's not turning on
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    All the wires are hooked up correctly, I have the pink radio on wired in as well so that the amp turns on. RF LF RR LR +/- are all wired in correctly to the head unit. The amp turns on and the 4" deck woofers and the 5 1/4" door speakers work fine but the 6x9's will not turn on and I don't understand why.
    This is a wiring diagram for the grand prix w/ bose 2000PontiacGrandPrixRadioWithAmp.pdf (download)
    I won't wire anything extra in, I've read that it can be done by just wiring the pink radio on wire in. Before the aftermarket head unit, the 6x9 speakers worked.
  2. #2 Re: 2000 Grand Prix Bose wiring diagram, woofers work, 6x9's not turning on
    Sounds like the 6x9s are done for, if it was an issue with the head unit or the amp none of the speakers would work I am pretty sure. And yes you just hook the turn on lead to the pink wire in the factory harness.
  3. #3 Re: 2000 Grand Prix Bose wiring diagram, woofers work, 6x9's not turning on
    Apr 2011
    St. Louis
    I will look into that. The other thing is that the system sounds better when I fade the head unit completely to the front & even with this setting, the woofers stay on.
  4. #4 Re: 2000 Grand Prix Bose wiring diagram, woofers work, 6x9's not turning on
    Apr 2011
    St. Louis
    Technically, I don't know why it doesn't work, maybe someone can explain, but I read on smd forums that you indeed need the pac-oem1 to link the bose amplifier correctly with the stock sound system. The wiring doesn't look any more complicated than a typical stereo install.
  1. wiring diagram 97-03 stereo with bose where there few wires do?
    By wild2crazy in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2014, 10:14 AM
  2. Replies: 0
    Last Post: 07-19-2012, 07:16 PM
  3. Wiring diagram for a dimming mirrior for a 99 GP, Only 97-00 will work!
    By Iron Indian in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2010, 10:19 PM
  4. Fuel pump wiring diagram for 1996 Grand Prix LE with a 3.4L
    By 96LimitedEdition in forum General Tech Discussion
    Last Post: 07-23-2009, 01:03 PM
