Thread: Sparked the battery now nothing works
Results 1 to 7 of 7
  1. #1 Sparked the battery now nothing works
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    hey guys, feel really stupid after this one... but with my car sitting all winter i went to put a battery tender on it and while bolting down the possitive (the negative still connected) the wrench i was using hit metal and sparked pretty good. now nothing works no power locks and car wont start. the power locks will actually try and work and after clicking the button a couple of times they will work but the car wont start at all. shortly after the whole system kinda tweaked out too. i think its just a blown fuse but none of the fuses appear to be blown... anybody done this before? suggestions? thanks guys!
    2005 Bleen Base GP-20% Tint, Sound System, Underglow, HIDs, DIY Intake-SOLD
    2008 BLACK GXP-20% Tint 35% on Windshield w/ 5% Strip, Touch Screen, 20" Bazo Rims
    2006 Suzuki GSXR600-Blue & White, Arrow Exhaust, Black Windshield, Million Color LED Glow
  2. #2 Re: Sparked the battery now nothing works
    I would test the relays and resisters in the fuse boxes.
  3. #3 Re: Sparked the battery now nothing works
    Oct 2011
    Toledo, OH
    Fuses can blow without looking blown. I'd unplug the battery completely, and test each fuse with a multimeter instead of just visually.
    7"
  4. #4 Re: Sparked the battery now nothing works
    Dec 2012
    Where 4T65E's were born
    What is the voltage of the battery? Not sure what fuse would blow from direct positive to a grounded metal body surface. There are no fuses in the big ground cables.
    Sold.
  5. #5 Re: Sparked the battery now nothing works
    Nov 2011
    Decatur
    the battery is testing normal
  6. #6 Re: Sparked the battery now nothing works
    Nov 2012
    Madison
    Battery sounds dead and thats about it.
    Leave the tender on it until the light stays green(fully charged). This may take a day or two.
    Get a multi meter and check the battery when the tender is on it. You should see the digits climb fairly quick when the battery is low.
  7. #7 Re: Sparked the battery now nothing works
    SE Level Member jimzssei's Avatar
    Sep 2014
    Sounds like a bad ground .
  1. A product that actually works
    By lewis1952 in forum Visual/Body Modifications
    Last Post: 07-03-2014, 01:14 PM
  2. Only one HID works
    By TeacherCreature in forum General Tech Discussion
    Last Post: 07-04-2013, 04:37 PM
  3. How Axe really works....
    Last Post: 07-30-2011, 11:32 PM
  4. 99 GTP A/C works great, then stops, then works great again
    By stotzbotz in forum General Tech Discussion
    Last Post: 09-27-2009, 02:39 PM
  5. It Works!!!
    By 02BlueGT in forum PCM Tuning
    Last Post: 08-31-2008, 01:02 AM
