Thread: Dash Lights, Radio Display out on 2005 Grand Prix
Results 1 to 3 of 3
  1. #1 Dash Lights, Radio Display out on 2005 Grand Prix
    Dec 2014
    Ohio
    The red lights on the dash that are around the gauges are out on my 2005 grand prix. The radio display is also out, and it started to fade and show half of the display before it went out completely. The dimmer does not work either as well as the gear shift lights and door lights (where the window controls are). The Windows, radio, and everything are functioning as they should, but the lights do not. The Mileage and Date Display above the radio, check engine lights, turn signal, and bright symbol on the dash all work. I do not believe it is any of the fuses, I went through and tested a lot of them. Does anyone know what could be causing this? Any help is appreciated.
  2. #2 Re: Dash Lights, Radio Display out on 2005 Grand Prix
    GTP Level Member simbah's Avatar
    Lala land
    Test the dimmer switch or replace with one from junkyard.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: Dash Lights, Radio Display out on 2005 Grand Prix
    Apr 2009
    ohio
    Check the 10A fuse labeled PK LP. It is located in the smaller fuse panel at the end of your dashboard passenger side front seat. This fuse would be more accurately labeled as "The fuse that controls parking lamps AND all interior lighting that is dimmable".
  1. dic lights,radio lights hud display..not working but is it a big deal if they dont?
    By wolfgang in forum Audio, Security & Visual Electronics
    Last Post: 05-21-2013, 07:34 AM
  2. 2006 Grand prix radio display
    By Zetah in forum Audio, Security & Visual Electronics
    Last Post: 02-02-2013, 06:12 PM
  3. Dash light and Heads up display won't work on 97 Grand Prix GT
    By PANTHERFAN89 in forum General Grand Prix Discussion
    Last Post: 09-13-2012, 03:18 PM
  4. Dash Light and Heads up display won't work on 97 Grand Prix gt
    Last Post: 08-04-2012, 04:08 PM
  5. 1996 Pontiac Grand Prix SE radio/clock display
    By moospis in forum General Tech Discussion
    Last Post: 08-03-2011, 03:58 PM
