Thread: ipad mini install
Results 1 to 20 of 38
  1. #1 ipad mini install
    Nov 2014
    IN
    I'm working in installing an iPad mini into my dash. I know how I'm doing it and how to do it. but I don't want to make a mold out of fiber glass. is it possible for me to use pc7 epoxy to form the mold with mesh to help hold it together? It says online it hardens like plastic and is sandable. Will it hold up for a long time?
  2. #2 Re: ipad mini install
    Nov 2014
    IN
    Here's the start of this project. Did some work with a dremel. I know it's sloppy, but now I need to fiberglass my iPad to the dash and use some pc7 epoxy to clean up all of the edges. That won't be for a few weeks. So here's there start!
  3. #3 Re: ipad mini install
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    subbed
    2005 Bleen Base GP-20% Tint, Sound System, Underglow, HIDs, DIY Intake-SOLD
    2008 BLACK GXP-20% Tint 35% on Windshield w/ 5% Strip, Touch Screen, 20" Bazo Rims
    2006 Suzuki GSXR600-Blue & White, Arrow Exhaust, Black Windshield, Million Color LED Glow
  4. #4 Re: ipad mini install
    I know this isn't in a GP but it will help you get some ideas as how to mount and wire stuff up http://www.tahoeyukonforum.com/forum...ad.php?t=49671
  5. #5 Re: ipad mini install
    Oct 2011
    Toledo, OH
    I wonder if you could have found a Double DIN bezel that pad would fit nicely in.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  6. #6 Re: ipad mini install
    I thought the 04+ GPs were double din?
  7. #7 Re: ipad mini install
    Oct 2011
    Toledo, OH
    Quote Originally Posted by Slick2500 View Post
    Yep, I meant like the mount for Double DIN radios, not the cars bezel itself.
    7"
  8. #8 Re: ipad mini install
    Quote Originally Posted by industrialfish View Post
    Oh look in the link I posted the dude made his own with an ebay case, some Plexiglas and a bic pen.
  9. #9 Re: ipad mini install
    http://www.gpona.com/forums/appearan...-a-t26104.html
    Might help you out
    04 Comp G.
  10. #10 Re: ipad mini install
    Might help you out
    http://www.gpona.com/forums/appearan...lf-t26202.html
    04 Comp G.
  11. #11 ipad mini install
    Obviously the mini would look more in place and not out of place like the original iPad looked. For a mold you could cover up the iPad (and I do mean cover up!) and fiberglass over the backside to get a mold of the backing and somewhere make a notch so that you could pop it in and out as needed. Would be plenty strong then sand/paint and mold it to the bezel.
    Or find a case that will work and mold that into the bezel.
    04 Comp G.
  12. #12 Re: ipad mini install
    Nov 2014
    IN
    That's actually what I'm doing. Taping the whole iPad and then wrapping it in aluminum foil. Then I Wil fiberglass the back side of it!
  13. #13 Re: ipad mini install
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by benromero693 View Post
    Forgive my ignorance, but will the aluminum foil interfere with the wireless communication side of it?
    Also, if you encase it in plastic wrap or other items, will it cool properly? I'm pretty sure the cooling is passive, not sure if there is a problem with putting what is essentially insulation around it.
    Good luck with the project! Just trying to give you a few things to consider.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  14. #14 Re: ipad mini install
    Nov 2011
    Decatur
    found this video randomly today and remembered your question... thought it may help!
    https://www.youtube.com/watch?v=bcwqHF65hMw
  15. #15 Re: ipad mini install
    Nov 2014
    IN
    Does anyone know what adapters I need to do what the guy did in his Yukon? I had planned on putting a Bluetooth stereo in the glove box and using the iPad through Bluetooth. But I would deffjnately rather just wore the iPad to a wiring harness with no stereo at all.
  16. #16 Re: ipad mini install
    What year gp? If it's an 04+ the adapters he links to should work. Obviously you want the ipad cable instead of the cable for the Galaxy. If its a 97-03 you might be stuck doing the receiver in the glove box.
    Sent from my Galaxy Far Far Away
  17. #17 Re: ipad mini install
    ^ 04+ based on the bezel pictured.
    04 Comp G.
  18. #18 Re: ipad mini install
    Oh **** sorry I was on my phone, and didn't realize he was the op lol. Then yes the adapters he linked in that thread will work for your gp as they use the same adapters.
  19. #19 Re: ipad mini install
    Nov 2014
    IN
    Even though I have the monsoon sound system, it'll still work?
  20. #20 Re: ipad mini install
    Yup checked it out it will work. You could wire up everything just like he did too.
  1. iPad trobble
    By kjohnson in forum Off Topic Discussion
    Last Post: 01-25-2011, 04:50 PM
  2. ipad good or wast
    By Davisgtp in forum Off Topic Discussion
    Last Post: 01-31-2010, 07:46 AM
