Thread: HID issue in 2008 GP
Results 1 to 11 of 11
afish70 HID issue in 2008 GP 12-28-2008, 09:44 PM
BackInBlack Re: HID issue in 2008 GP 12-28-2008, 10:14 PM
Clar2478 Re: HID issue in 2008 GP 12-29-2008, 02:03 AM
afish70 Re: HID issue in 2008 GP 12-29-2008, 08:48 AM
Clar2478 Re: HID issue in 2008 GP 12-29-2008, 01:41 PM
The Guz Re: HID issue in 2008 GP 12-30-2008, 12:10 AM
KingOfTheSouth Re: HID issue in 2008 GP 12-30-2008, 11:41 PM
afish70 Re: HID issue in 2008 GP 01-05-2009, 01:30 AM
Clar2478 Re: HID issue in 2008 GP 01-05-2009, 01:42 AM
KingOfTheSouth Re: HID issue in 2008 GP 01-06-2009, 05:41 PM
KingOfTheSouth Re: HID issue in 2008 GP 01-06-2009, 05:42 PM
  1. #1 HID issue in 2008 GP
    SE Level Member afish70's Avatar
    Naperville, IL
    okay so I just installed a set of HID's in my 08 base. they look awesome at night. my issue is that during the day when the drl's are supposed to be on i get this wierd buzzing noise coming from under the hood. when I purchased the HID's I also purchased and installed the relay kit is the kit gets direct power from the battery and only is supposed to use the factory harness as a switch. the lights never come on when in DRL mode. can someone tell me what I did wrong?? please help..
  2. #2 Re: HID issue in 2008 GP
    GT Level Member BackInBlack's Avatar
    Vermont
    Most likely, the DRL lower brightness is driven by a PWM (pulse width modulation) circuit that is chattering the relays. This is a BAD thing. You'll need to completely disable the DRL function or you WILL damage your relays and ballasts. IIRC, the DRL control module handles all the headlamp functions, so this will be no easy task. You may have to go all the way back to the headlamp switch and tap the "headlamps on" trigger directly to enable your relays under the hood, and completely ignore the stock headlamp connectors.
    Until you get this resolved, I HIGHLY recommend that you remove your HID and relay kit for the time being.
    The GPs are long gone...
  3. #3 Re: HID issue in 2008 GP
    GT Level Member Clar2478's Avatar
    Nov 2008
    Idaho
    I would remove the relay kit and just get some black electrical tape and cover the light sensor on the dash. It will make your car think that its always night so the lights are always on. then you dont have to worry about the daytime lighting.
  4. #4 Re: HID issue in 2008 GP
    Naperville, IL
    but by covering that sensor i also lose the temp in my DIC, don't I?
  5. #5 Re: HID issue in 2008 GP
    Nov 2008
    Idaho
    you shouldn't. I have an '06 and i've done the same thing, my temp still shows up.
  6. #6 Re: HID issue in 2008 GP
    Dec 2008
    Lawndale, CA
  7. #7 Re: HID issue in 2008 GP
    SE Level Member KingOfTheSouth's Avatar
    Nov 2008
    homestead
    TAKE IT TO A SHOP AND GET IT DONE RIGHT THESE ARE THE REULTS
  8. #8 Re: HID issue in 2008 GP
    Naperville, IL
    and where is this shop? since i am in the western burbs of Chicago i want to know which shop to take it to. what exactly did they do anyways that is different from anyone else?
  9. #9 Re: HID issue in 2008 GP
    Nov 2008
    Idaho
    Quote Originally Posted by afish70 View Post
    Charged you money
    Call me Brad
    '06 GT: Just a few mods here and there.
  10. #10 Re: HID issue in 2008 GP
    Nov 2008
    homestead
    well they by passed the light sensor on the dash to where my day light running lights run in the day with out my fogs and they warranty there work so if any screw up happens its up to them to fix it when your running six convertors some relays aint just gonna do the job
  11. #11 Re: HID issue in 2008 GP
    Nov 2008
    homestead
    and finding a shop in chicago can be to hard now im pretty sure theres some somewhere there
  1. Ride For Pride 2008
    By stkks in forum Southeast
    Last Post: 06-15-2009, 01:53 PM
  2. My 2008 GXP HAS NO BRAKE LIGHTS
    By tas1977 in forum Brakes/Suspension/Chassis
    Last Post: 01-25-2009, 03:20 AM
  3. 2008 grand prix
    By KingOfTheSouth in forum Off Topic Discussion
    Last Post: 11-05-2008, 07:47 AM
  4. My 2008 Mods
    By Keifer in forum General Tech Discussion
    Last Post: 07-02-2008, 11:06 PM
  5. Bgpm 2008
    By webracin in forum Shows and Events
    Last Post: 01-22-2008, 02:19 PM
