You can with a little time
Check this out......
http://www.grandprixforums.net/threa...=anthony+smith
jeez man have you ever used fiberglass and sand paper? its not hard get your dimensions, mark it with a marker, cut it out, glass it to keep it strong and looking decent then paint it. not rocket science.
You got me messed up if you think ima do it myself! Im 18 and have never worked on a car! Ive contacted a shop and they are gonna do it for me
Why not ask the shop if they can do the job?
im 21 and im on my 2nd motor build, plus ive got my fiberglass practice on sub boxes, next is my car. age has nothing to do with it, having a vagina not to try it out does :)
^^^^This^^^^ I was trying to be nice, but I forgot to fill up my "gives a sh!t" tank today. Grow a pair and try it. Those pieces are so easy to find in a JY if you mess yours up too bad. This also gives you something that your friends call upon you to do one day, and then money can be had for more mods.........quit being a Sally.
like ^
Hey guy,
I understand being scared to try but like they said pieces are easy to find in a JY, also you can use the JY as a training ground on how to take it apart and put it back together. You can even wire the radio yourself with a adapter you can get at walmart it is color coded and easy. But shops today chage a fortune and half of them do a crappy job and you end up redoing it. If you don't try you will never learn and learning gives you more money to spend on other things, it gives confidence and helps you hold your own in a conversation on cars also you can make new friends in various car clubs and something bond with your kids with when you have them
Why has no-one linked to this? http://shop.doubledmods.com/Pontiac-...rixDDbezel.htm
If you cant do the work yourself that is probably your best bet.
Edit
Nevermind
