Thread: replace rear turn signal with bulb
Results 1 to 3 of 3
  1. #1 replace rear turn signal with bulb
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    hey guys so i just bought a beautiful black gxp 2008. what do you know within a week the rear turn signal goes out on the pass side. seems like the perfect opportunity to replace them with some leds! so i went to oreilleys and picked up some white leds and a resistor kit. when you unplug the turn signal it has a black wire brown wire and yellow wire. i assumed black was ground so hooked the resistor up to it. now my choices are brown or red for the poss side of the resistor. when no resistor is hooked up it doesnt really hyperflast it causes all lights to flash almost like hazzards are on. when i hooked it up to both the brown and the yellow same thing happened nothing changed. even tried the other resistor to see if maybe mine was bad. im completely thrown on what is going on, any ideas? i read somewhere that i may need to add a resistor the the front turn wire as well? thanks!
    2005 Bleen Base GP-20% Tint, Sound System, Underglow, HIDs, DIY Intake-SOLD
    2008 BLACK GXP-20% Tint 35% on Windshield w/ 5% Strip, Touch Screen, 20" Bazo Rims
    2006 Suzuki GSXR600-Blue & White, Arrow Exhaust, Black Windshield, Million Color LED Glow
  2. #2 Re: replace rear turn signal with bulb
    Nov 2011
    Decatur
    Also note that the other lights that flash don't flash as bright as the turn signals but still flash
  3. #3 Re: replace rear turn signal with bulb
    Nov 2011
    Decatur
    Update when car is running just have hyper flash but tried wiring to yellow and to grey wires and nothing changes. Anyone have a wiring diagram
  1. Replies: 7
    Last Post: 10-09-2014, 08:43 PM
  2. !Rear turn signal But no Tail Light!
    By klj5022 in forum General Tech Discussion
    Last Post: 12-25-2013, 12:37 PM
  3. Right Rear Turn Signal Out But Light Is Still On?
    By Joseph27705 in forum General Tech Discussion
    Last Post: 06-28-2012, 06:01 PM
  4. Front Signal Bulb
    By madmike187 in forum General Tech Discussion
    Last Post: 12-19-2008, 08:52 PM
