Thread: Rear deck speaker install
Results 1 to 5 of 5
  1. #1 Rear deck speaker install
    Apr 2014
    Albuquerque New mexico
    So I found some descent 6*9 pioneer speakers in the jy and picked them up, how do i get the old speakers out and the new in? I looked at one in the junk yard and saw how to remove the speakers but how do i get the plastic cover off without breaking it
    2003 gtp, 3.4 pulley, ported sc, pacesetter ceramic headers, northstar tb, lq4 maf, HAI, wideband tuned
    245/45/17 on cobra wheels.
  2. #2 Re: Rear deck speaker install
    Remove the rear seats, then take the push clips out and it will lift up and off the rear deck.
  3. #3 Re: Rear deck speaker install
    Apr 2014
    Do the rear seats just pop out or is there hardware that has to be removed?
  4. #4 Re: Rear deck speaker install
    St. Louis
    The seat bottom should just pop loose. IIRC you push back on it from the front edge and pull up but it's been awhile since I had mine out. The seat back has to have the seatbelt bolts removed. IIRC there are a torx bit (T-45 or 50).
  5. #5 Re: Rear deck speaker install
    GTP Level Member
    springfield IL
    4 bolts... seat belt bolts and two smallers nuts. you will see them after you remove the bottom seat
  1. Driver Side Rear Deck Speaker
    By gmildner13 in forum Audio, Security & Visual Electronics
    Last Post: 09-26-2013, 03:08 PM
  2. Rear Deck Speaker Replacement
    By Lishap in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2013, 01:05 AM
  3. Remove rear speaker grill, not the whole deck
    By BeastGT in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2011, 03:41 PM
  4. Rear Deck Speaker Installation
    By garreTT in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2011, 12:43 PM
  5. Rear Deck Speaker Grilles
    By SlowNA06 in forum Audio, Security & Visual Electronics
    Last Post: 05-25-2010, 12:18 PM
