Thread: Date on Dash not saving
Results 1 to 3 of 3
  1. #1 Date on Dash not saving
    Mar 2013
    Canada
    Im not sure if this has to do something with it but I change my radio with an after market Double din and I use the GMOS-01 harness to retain the door chime. During the install I pulled the negative feed from the battery, what im noticing now is when I set the date on the Driver Information Center (Dash Screen) it is not saving it. It will reset itself after 20 seconds. Any thought what may be the issue? Vehicle is a 2008 Grand Prix
  2. #2 Re: Date on Dash not saving
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by ibra0078 View Post
    The date function of the DIC runs through the OEM head unit. I believe it uses its clock to know when to change the date.
    You'll need to use a different default screen. I use the average fuel economy screen.
  3. #3 Re: Date on Dash not saving
    Mar 2013
    Canada
    Perfect thanks
  1. Saving a 99 SE from the Scrapper
    By Brian99SE in forum Visual/Body Modifications
    Last Post: 08-22-2012, 09:54 PM
  2. Time to start saving for a GTP
    By ImColeTrickle in forum General Grand Prix Discussion
    Last Post: 01-27-2012, 03:05 PM
  3. Uv scan not saving data
    By Z34Phoenix in forum PCM Tuning
    Last Post: 06-28-2011, 01:51 PM
  4. Possibility of saving motor
    By FordMan77 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2010, 12:11 PM
  5. Saving money instead of spending on my car...
    By Quicklynx in forum Off Topic Discussion
    Last Post: 10-11-2008, 08:00 PM
