I get the general idea of it, just was hoping for a writeup, possibly with picture's of how the wires were routed among a few other concerns I have about it that pictures would answer easily enough. TIA
speaking of the wire upgrade that uses larger gauge wire from alternator to positive battery terminal, ground to negative battery terminal, and ground to engine block.
When you install the upgraded wires, is it necissery to disconnect the old wire from the alternator?
No, keep the old wire there also
yeah keep the old wires there, no need to remove them and the more wire the better, even though the current will take the path of least resistance
