Thread: Key Fob Half Working
Results 1 to 9 of 9
  1. #1 Key Fob Half Working
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    So my key fob for my 05 GP is only half working. I put a battery in it since it wasn't working at all. Now the alarm will work and the trunk will pop but the doors won't lock or unlock and the remote start will not work.
    So not sure if the remote is bad or if the car doesn't recognize the remote or what. I have no idea how these work.
    I went NA when a whore left -$300 in my bank account.
  2. #2 Re: Key Fob Half Working
    open it back up, then use rubbing alcohol and Q tips to clean the board and the button pads. should fix it up.
  3. #3 Re: Key Fob Half Working
    Jan 2012
    Indianapolis
    So are the button pads conductive somehow? I don't get how pressing the buttons does anything if they're not?
    I cleaned them up gonna go try and see if it works now.
  4. #4 Re: Key Fob Half Working
    they have metallic coating on the button pads, those round things under the buttons. they get dirty, and the wires on the board get dirty.
    if you put the battery in and take a coin to the board where the buttons touch the doors will unlock/lock.
  5. #5 Re: Key Fob Half Working
    Jan 2012
    Indianapolis
    Ok so now it locks and unlocks and the button for the remote start will make the car chime and the dash says remote start disabled.
    I've heard if the car has a trouble code. There's no MIL on and the light is working as it lights up on the bulb test. ABS light is on but I wouldn't think that would do anything.
    So whats next Scotty?
  6. #6 Re: Key Fob Half Working
    Enfield, CT
  7. #7 Re: Key Fob Half Working
    Enfield, CT
    O **** didn't read your post my bad lol
  8. #8 Re: Key Fob Half Working
    Jan 2012
    Indianapolis
    That's a good idea ^^ Thanks for posting that.
    I'll probably do that. It'll help so I don't have to press hard. But now I need to figure out why it's saying the remote start system is disable on the DIC
  9. #9 Re: Key Fob Half Working
    Enfield, CT
    It has to do with how many times the button was pushed during a short time frame. Had this issue when I was dicking around with the remote start. I forgot the instructions but it's in the owners manual
  1. Only getting half boost on DIC.
    By ls1racer11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2012, 11:40 PM
  2. Half Boost!!!
    By blackhawk gtp in forum General Tech Discussion
    Last Post: 11-03-2012, 12:10 AM
  3. 2006 Grand Prix Radio display half working
    By ffbwizard in forum Audio, Security & Visual Electronics
    Last Post: 07-08-2011, 06:32 AM
  4. gauges backlight and AC only half working ?
    By kellyadam in forum Introductions/Noob Questions
    Last Post: 05-05-2010, 12:06 AM
  5. Half a tank of 91 And half a tank of E85?
    By JbrownGTP in forum General Tech Discussion
    Last Post: 12-21-2009, 11:07 PM
