Is there power in the doors for the little empty 194 sockets? can you use the stock door pins for anything? or is this a full run wires to every door, buy sockets/bulbs/relay adventure?
Assuming you are 01. You need to run the wires. You can tap off the interior light circuit
Make sure you use both wires off the interior circuit.. it's not just a power and ground
I will have to see if this is an easy fit for my '04. I just thought they were reflectors with no space behind them. Going to have a look now.
On a whim..I thought Burgandy had done it as well.. looks like it's the only thing he didn't do. And..he's not an 04+
I did it on my Regal, but in 2000 I simply added it back into the connectors where it would have been in 1999.
