Thread: Front 3057 Turn "Place Holder" ??
Results 1 to 3 of 3
Blake71091 Front 3057 Turn "Place... 06-01-2014, 12:58 PM
Russosaur Re: Front 3057 Turn "Place... 06-01-2014, 02:37 PM
nik12937 Re: Front 3057 Turn "Place... 06-02-2014, 11:56 AM
  1. #1 Front 3057 Turn "Place Holder" ??
    Jun 2013
    N/A
    How do I trick my car into thinking this light is working without keeping a bulb in the socket. I'm doing something where I don't need the bulb.
    Thanks guys
  2. #2 Re: Front 3057 Turn "Place Holder" ??
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Try to match the resistance of the bulb with a resistor would be a guess, im no electronic guru but its a thing that popped into my head. What exactly are you trying to do?
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Front 3057 Turn "Place Holder" ??
    Pennsylvania, USA
    A 6-ohm resistor should work nicely, same idea as putting in a resistor when you install switchback turn signals. Either solder/splice it across the wires, or maybe even connect it to the base of an old 3057 bulb and plug it in so it can be swapped out quicker.
    If you're going to be sending a signal to that socket still (turn signals or hazards), you may want to go for one rated for 50W, or at least 35W, because they can get hot after feeding bulb power to them for extended periods of time. Diode Dynamics has them actually, basically just a 6-ohm resistor with a big heatsink integrated.
  1. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. "Front right turn signal out" then comes back
    By Scott Gerhart in forum General Grand Prix Discussion
    Last Post: 11-12-2012, 03:20 PM
