Thread: Whats needed to power the empty lights in the 4 door, door panels?
Results 1 to 6 of 6
  1. #1 Whats needed to power the empty lights in the 4 door, door panels?
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    Is there power in the doors for the little empty 194 sockets? can you use the stock door pins for anything? or is this a full run wires to every door, buy sockets/bulbs/relay adventure?
  2. #2 Re: Whats needed to power the empty lights in the 4 door, door panels?
    Assuming you are 01. You need to run the wires. You can tap off the interior light circuit
  3. #3 Re: Whats needed to power the empty lights in the 4 door, door panels?
    May 2014
    Colorado
    Was hoping that wasn't the case. O-well the cars mostly apart already, what better time than now.
  4. #4 Re: Whats needed to power the empty lights in the 4 door, door panels?
    Make sure you use both wires off the interior circuit.. it's not just a power and ground
  5. #5 Re: Whats needed to power the empty lights in the 4 door, door panels?
    Nov 2009
    PACNW
    I will have to see if this is an easy fit for my '04. I just thought they were reflectors with no space behind them. Going to have a look now.
  6. #6 Re: Whats needed to power the empty lights in the 4 door, door panels?
    On a whim..I thought Burgandy had done it as well.. looks like it's the only thing he didn't do. And..he's not an 04+
    I did it on my Regal, but in 2000 I simply added it back into the connectors where it would have been in 1999.
  1. 2 door and 4 door Body Panels
    By BlackGT97 in forum General Grand Prix Discussion
    Last Post: 02-26-2012, 06:48 PM
