Thread: No power after radio removal
Results 1 to 15 of 15
  1. #1 No power after radio removal
    GT Level Member K Slice's Avatar
    Jul 2013
    Traverse City MI
    Like it says, I took the old Alpine deck out, found the previous owner had done the install right and not cut the harness up! I figure hey, this will be an easy job. Attach the new Pioneer to the connector the alpine had on it, plug it all in, aaaand... nothing. And not just no power to the radio, no power at all on the 12V wire all the way back to the factory plug! Switched 12V works fine but the constant 12v wire (yellow on the aftermarket harness, orange on the car) has no power at any time no matter where the key is...
    What could have possibly gone wrong??
    Oh, and it's not the fuse. Already pulled that out and it had 0 ohms on it...
  2. #2 Re: No power after radio removal
    Never Never Land
    There's another radio fuse under the hood if you have a GP. Check that.
  3. #3 Re: No power after radio removal
    Jul 2013
    Traverse City MI
    Found it, but that fuse also checks out fine.
  4. #4 Re: No power after radio removal
    Jul 2013
    Traverse City MI
    According to the manual the only radio fuse is in the glove compartment.
  5. #5 Re: No power after radio removal
    Enfield, CT
    there IS one under the hood
  6. #6 Re: No power after radio removal
    Jul 2013
    Traverse City MI
    The harness I saved was just the pigtail which plugs into the factory plug that would go in the back of the factory radio. I matched the wires on that up with the ones on the pigtail which came with the Pioneer. And last I checked, there is very little power on the factory plug and glove box fuse (my meter reads a few mV) but the radio fuse under the hood has 12V.
  7. #7 Re: No power after radio removal
    GrandPrix Junkie
    St. Louis
    So you removed an Alpine deck, and installed a Pioneer deck but didn't change the harness adapter? Could be the issue right there. If the Pioneer uses a different pinout then you will have to get a different harness to match the new deck. That or the existing adapter harness is damaged since you have power at the factory harness. What happens if you connect the old Alpine deck again?
  8. #8 Re: No power after radio removal
    Jul 2013
    Traverse City MI
    I did like the way it used to stay on until the door was opened... But if I can't figure this out that may be what I have to do.
    Oh, but that probably has to do with just the remote wire anyways doesn't it. hmmmmm
  9. #9 Re: No power after radio removal
    why not just do a add a fuse and run a new power line to the radio?
  10. #10 Re: No power after radio removal
    re use the radio fuse should act the same.
  11. #11 Re: No power after radio removal
    Jul 2013
    Traverse City MI
    Plenty of voltage at the radio fuse under the hood but (basically) none at the fuse inside the car.... Just makes no sense.
  12. #12 Re: No power after radio removal
    theres more then one power source that stays on after the key is off and before the door opens.
    power port for one.
  13. #13 Re: No power after radio removal
    Jul 2013
    Traverse City MI
    I'd need a constant for this though, otherwise I'd never keep radio memory.
  14. #14 Re: No power after radio removal
    you can run the memory line to the battery or other full time hot fuse in the fuse box. stuff like the power windows work till the door is opened too if the power port is full time.
    the ign fuse should be hot full time. you just need to poke the fuses with a test light key off door open till you find one that has power.
  15. #15 Re: No power after radio removal
    Jul 2013
    Traverse City MI
    Have to do that tomorrow. Thanks for the help. So much for my simple radio swap..
  1. Help please!! No power to aftermarket HU after Bose amp removal
    By mick777wauchope in forum General Tech Discussion
    Last Post: 06-06-2013, 06:13 AM
  2. Removal of stock radio
    By burgundybullet in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2011, 06:44 PM
  3. Power Sunroof Switch Removal
    By cazanowick in forum General Tech Discussion
    Last Post: 03-14-2011, 09:56 PM
  4. Radio removal
    By longslide10 in forum Audio, Security & Visual Electronics
    Last Post: 12-26-2008, 01:46 AM
  5. Stock radio - CD removal
    By MichEE in forum Audio, Security & Visual Electronics
    Last Post: 08-17-2008, 02:08 AM
