Thread: Help me pick a 2Din HU
Results 1 to 9 of 9
  1. #1 Help me pick a 2Din HU
    Apr 2011
    Vassar, Mi
    Im losing my mind trying to decide! I want a ~6" screen so it isnt motorized and it still has a volume knob. Must have built in BT. preferably under $400. This is what ive come up with so far
    Sony XAV-64BT
    Pioneer AVH-X2600BT
    Kenwood DDX371
    AND my top choice unless someone talks me out of it
    JVC KW-V20BT
    http://www.crutchfield.com/App/Produ...8XAV64BT&g=300
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  2. #2 Re: Help me pick a 2Din HU
    Feb 2014
    Grand Forks, North Dakota
    I had the Sony XAV-64BT in my chevy trailblazer I had. I really liked it, but sold it because it didnt fit my grand prix (2002) because they are 1 DIN. It had all the features you could possibly want.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  3. #3 Re: Help me pick a 2Din HU
    GTP Level Member nik12937's Avatar
    Pennsylvania, USA
    This may just be me, but the last JVC double-DIN I had just decided to die on me about 2 years after I got it. I opened it up completely and in spite of being family experienced with electronics and circuitry, I couldn't find the problem. It would just turn on and the screen would stay black. It was one of the last generation Double-DIN multimedia head units.
    I have the Kenwood Excelon DDX790 now and I love it. Feature wise it's very similar to the JVC but I like that the parametric EQ lets you fine tune the lows a bit more than the JVC did. Literally my one gripe is that the bluetooth is a little delayed. It'll take a second after hitting skip for my phone to actually change songs, but it doesn't really bother me. If you go with the Kenwood, I'd honestly spend the extra $50-100 to get the DDX790 over the DDX371. The buttons are relocated on the bottom so you actually get a bigger screen, one of the biggest I've seen in a double-DIN at least
  4. #4 Re: Help me pick a 2Din HU
    Apr 2011
    Vassar, Mi
    I don't really want a 7" screen. I would rather not have the motorized faceplate that has to flip down to expose the cd slot. Just more stuff to break. Also based on everyone I know that has had one and all the gripes in the consumer reviews, the HU's in my budget range of under $400 generally have sub par touch functions. So I would rather have a physical volume knob and real buttons still so I don't have to fiddle with a chunky touchscreen just to turn the volume down or change a song.
    It will be going in my 99 too, I'm just going to hack the dash up and make it fit
  5. #5 Re: Help me pick a 2Din HU
    Nov 2011
    NY
    Why cut everything apart for a double din without touch screen? That's the only reason I can see going through the trouble to do it. I for one would go for best sound within your budget, something like:
    http://www.pioneerelectronics.com/PUSA/Car/CD-Receivers/DEH-80PRS
    Just my $.02
  6. #6 Re: Help me pick a 2Din HU
    Apr 2011
    Vassar, Mi
    No...I'm still getting a touch screen...not a 7 inch screen where the whole face is a screen with like 2 tiny buttons across the bottom. I want one with a 6" screen and a button console down the side with real normal size buttons and a volume knob
  7. #7 Re: Help me pick a 2Din HU
    Feb 2013
    Detroit, MI
    Go for this one if you want it like that. http://www.ebay.com/itm/Pioneer-AVH-...item4d1a9a5c11
  8. #8 Re: Help me pick a 2Din HU
    Apr 2011
    Vassar, Mi
    Quote Originally Posted by GrandPrix06GT View Post
    do you have one of those? the only thing I didnt like about that one was the 2V rca outputs, and its only 14w output on the internal amp. If I got it I would have to do a 4 channel on all the components right off the bat. That will be throwing down a lot of cash all at once. Im planning on getting a kicker 700.5 and a good set of front components too.
  9. #9 Re: Help me pick a 2Din HU
    Feb 2013
    Detroit, MI
    Ahh okay, yeah if you're running a couple amps you're screwed then. I have the avh 4500 bt, but that's a full 7 inch one. My brother has the one I just showed you n it's nice. I used to have the 2400bt. Check that one out, I forget if it had more rca ' tho.
  1. Help me pick my new car
    By Timing in forum General Tech Discussion
    Last Post: 08-08-2012, 03:30 PM
  2. Help Me Pick!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 07-19-2011, 12:52 AM
  3. Pick my next mod!
    Last Post: 05-15-2011, 09:50 AM
  4. Help Me Pick a New DD GPF!
    By blueguy in forum Off Topic Discussion
    Last Post: 04-13-2011, 02:10 PM
  5. help me pick
    By cjim in forum Tires & Wheels
    Last Post: 05-02-2010, 12:40 PM
