Hello guys
I have an 04 GTP with a monsoon sound system that needs new speakers. From what I understand:
rear 6x9's are fed with dedicated wires for low and high freq
front 6x3/4's are the same, that being said...I was told that buying aftermarket speakers will be problematic because I would only be able to hear low rumble distorted bass, or just the tweeters (depending on which wires are connected) this is (as I was told) due to the fact that aftermarket speakers come with only one "input."
Replacing the amp and/or headunit will fix all of this but that is not an option at this current time.
Any suggestions are greatly appreciated, also if I downright sound like I know nothing about car audio I DONT
the above information was given to me and i'm sure that I made errors in writing it ...so thanks in advance and please feel free to share your thoughts.
Edit--If I were to get a 4 channel aftermarket amp (which is looking like the only option at this point) would it work. is the factory amp 8 channels like i'm assuming? how would it work-if it even does, thanks again.
