Thread: speakers for 04 Grand prix with monsoon
Results 1 to 4 of 4
  1. #1 speakers for 04 Grand prix with monsoon
    Jan 2014
    Washington D.C.
    Hello guys
    I have an 04 GTP with a monsoon sound system that needs new speakers. From what I understand:
    rear 6x9's are fed with dedicated wires for low and high freq
    front 6x3/4's are the same, that being said...I was told that buying aftermarket speakers will be problematic because I would only be able to hear low rumble distorted bass, or just the tweeters (depending on which wires are connected) this is (as I was told) due to the fact that aftermarket speakers come with only one "input."
    Replacing the amp and/or headunit will fix all of this but that is not an option at this current time.
    Any suggestions are greatly appreciated, also if I downright sound like I know nothing about car audio I DONT the above information was given to me and i'm sure that I made errors in writing it ...so thanks in advance and please feel free to share your thoughts.
    Edit--If I were to get a 4 channel aftermarket amp (which is looking like the only option at this point) would it work. is the factory amp 8 channels like i'm assuming? how would it work-if it even does, thanks again.
  2. #2 Re: speakers for 04 Grand prix with monsoon
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by ndbn View Post
    Hello guys
    I tried to replace the rear speakers in my car with Pioneer 4 ways and I was not impressed. The way the rear speakers are wired, there's a single channel that serves as a subwoofer, then you have the separate left and right channels for high. I don't know this for sure, but I suspect the Monsoon amp has crossovers set in it for the factory speakers. Despite the number of speakers in your car, it is a four channel system. I do not have the door tweeters or the center dash speaker integrated with my setup. You can get a component speaker setup if the tweeters are important - and the audio heads will tell you to mount those higher than the factory location, like the "A" pillar trim rather than the doors. I have 3 way speakers in the doors and I'm rather happy with that.
    I did what you're contemplating. I had already installed a head unit (Pioneer AVIC-Z150BH), which has three preamp outputs. I ran 3 pairs of RCA cables to the rear and new 14 gauge speaker wire to the front door speakers. I used a Pioneer GM-D8604 amplifier for the front and rear channels, and plugged the subwoofer output into a Bazooka powered bass tube. My system isn't built to simulate an earthquake, I've already destroyed part of my hearing. I was looking for a nice clean sound. Excluding the head unit, I've got maybe $400 invested in the amp, speakers and installation material.
    I would not add an amplifier to the factory head unit. There is too much hacking into wiring to make that work, and since you won't have the equalizer and crossover control that you'll have with most any nice head unit, I don't see it being worth the effort.
    Doing what I did is not for the faint of heart. If you do not have basic wiring experience, do not try this at home. If you're not comfortable with taking your interior apart, do not try this at home. Once you get it all installed, there is still setting up the amplifier gains and crossovers, as well as the equalizer and possibly crossovers in your head unit. Not knowing where to start with the settings is a vexing experience. You'll also need to deal with integrating your steering wheel controls and if you want, the OnStar to the head unit.
    If funding has you contemplating this job in pieces, I would strongly suggest you do the head unit part first, even if that's the most expensive part of the job. There is a dizzying array of double DIN head units out there. Is the amplifier quality most important to you? Do you want iPod integration? Hands free Bluetooth for your phone? Rear camera? Rear seat video outs so the kiddies can watch a video? Nav? All of that is available in today's head units and more. Google will certainly be your friend here. If you think you've zero'd in on a possibility, try to find a users forum and get a feel for what people think of their units. For example, while my unit is quite capable - and when I bought it, it was the most feature packed unit available - there are things it does not do as well as the advertising led me to believe it would.
    You've got quite a homework assignment - figuring out what you want with the budget you have to work with. Good luck.
    Oh, yeah. This might be a good place to start if you want to get up to speed as to what's what in car audio. I'd pay a bit less attention to some of the equipment they talk about - some of those guys gotta have more money wrapped up in their audio equipment than they do in the car itself.
  3. #3 Re: speakers for 04 Grand prix with monsoon
    Jan 2014
    Washington D.C.
    Thanks for the info douger. You said something interesting "I would not add an amplifier to the factory head unit. There is too much hacking into wiring to make that work, and since you won't have the equalizer and crossover control that you'll have with most any nice head unit, I don't see it being worth the effort." But wont a new aftermarket amp give me more flexibility in terms of what speakers I can get for my current situation?
    Another thing; I spoke to a crutchfield advisor and asked him if replacing my factory speakers with aftermarket component speakers is a good idea (and keeping stock amp), he said if the frequencies match or are close to what the stock amp can provide then technically it would work fine.
    Your thoughts are greatly appreciated.
  4. #4 Re: speakers for 04 Grand prix with monsoon
    Aug 2012
    Fort Wayne
    If you want to stay as stock as possible, what I might suggest is a low powered, self powered subwoofer like I have and installing a line output converter between the main cone connectors of the factory speakers and the subwoofer. That Bazooka tube of mine is a 100 watt unit and doesn't require cabling the size of your wrist to run. That setup would give you back your bass without a whole lot of hacking. In fact, that and a couple of nice three way speakers on the rear deck, and you might be very happy with the results. If you want all of the gingerbread that comes with an aftermarket head unit, you can add that later.
    Any full blown aftermarket amplifier that you might install will require some disassembly of the interior to run the power for it. Most moderately powered amps - and unless you're thinking about head throbbing music, 75 watts RMS is more than enough per channel - will require a minimum of 8 gauge wire for both the power and the ground. You'll also be running speaker wire at the same time, although it's not a good idea to run speaker wire with power runs. It tends to introduce noise.
    Let me know if I can answer any more of your questions.
  1. how to wire up rear 6x9 speakers to monsoon amp
    By Ferchak12 in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2013, 07:53 PM
  2. bridging monsoon rear speakers
    By biteme56 in forum Audio, Security & Visual Electronics
    Last Post: 10-16-2012, 03:08 PM
  3. Can I replace the Monsoon speakers?
    By jstevanus in forum Audio, Security & Visual Electronics
    Last Post: 06-25-2010, 07:50 AM
  4. Replacement Monsoon Speakers
    By bilak09 in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2010, 07:40 PM
  5. 04 GTP Monsoon rear (JUNK) speakers.
    By 04compgtp in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2009, 11:36 AM
