Thread: Kicker l7 question
Results 1 to 7 of 7
  1. #1 Kicker l7 question
    Feb 2008
    I have a 2001 grand prix gt 3.8 n/s. I also have a aftermarket sony xplod (gt500w head unit) a kenwood 9103d 1200 1- ohm stable amp and a 2009 kicker l7 solo baric 2- ohm dual voice coil amp. With all new boston speakers. The sub sits in its custom ported box but sounds like crap. its not blown but i have it hooked up running positive to positve and negative to negative i think this gives the 2-ohm sub a 1 ohm load im curisous becasue i hear some people tell me my amp is not a true 1 ohm amp is this why it sounds like ****.
  2. #2 Re: Kicker l7 question
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    IF the amp is not stable it will shut down.
    Many things it could be.
    Crappy amp.
    Crappy box. (usally #1 issue) the box will make or break a sub.
    Bad Crossover settings.
    how you internal wire the sub? was it SVC? DVC? ( all that will do though is tell the amp how many watts to push)
    Now when you say sounds like crap just loud and boomy? That is what L7 is good for
    Does not sound clean? You got the wrong sub.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: Kicker l7 question
    Feb 2008
    what is a good set of subs to get before i had the l7 i had 2 12" rockford fosgate p2s in a custom box. I didnt like the sound of those either i just want a sub that is LOUD and CLEAN
  4. #4 Re: Kicker l7 question
    GT Level Member reinke's Avatar
    Oct 2008
    cleveland, ohio
    i would check the settings on your amp:
    make sure the phase is set to 0
    have the x-over settings around 80hertz
    make sure your gain is set correctly and not clipping the sub
    make sure your box is tuned correctly and all joints are sealed
    make sure you head unit is set up properly.
    if you need more help just ask.
  5. #5 Re: Kicker l7 question
    Oct 2008
    cleveland, ohio
    if you want loud and clean i would recommend:
    american bass hd
    audiopulse any model
    re xxx or mt
    fi bl or q
    there are alot that will be clean and loud. it is really all up to the box and amp. installation is everything man.
  6. #6 Re: Kicker l7 question
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by reinke View Post
    american bass hd
    re xxx or mt
    fi bl or q
    you forgot digital designs
    02 GTP with mods 05 GP for DD
  7. #7 Re: Kicker l7 question
    Oct 2008
    cleveland, ohio
    yes i did. but they are up there in price with audiopulse. but, they have a amazing warranty
