Thread: Someone know how to remplace both airbags ?!
Results 1 to 11 of 11
darthcliff Someone know how to remplace... 10-21-2013, 01:09 PM
BillBoost37 Re: Someone know how to... 10-21-2013, 01:31 PM
darthcliff Re: Someone know how to... 10-21-2013, 01:45 PM
BillBoost37 Re: Someone know how to... 10-21-2013, 01:46 PM
darthcliff Re: Someone know how to... 10-21-2013, 01:56 PM
simbah Re: Someone know how to... 10-21-2013, 04:20 PM
goldgp Re: Someone know how to... 10-21-2013, 05:23 PM
00grandprixgtp Re: Someone know how to... 10-21-2013, 05:35 PM
00grandprixgtp Re: Someone know how to... 10-21-2013, 05:34 PM
Timing Re: Someone know how to... 10-21-2013, 05:55 PM
douger Re: Someone know how to... 10-22-2013, 08:58 AM
  1. #1 Someone know how to remplace both airbags ?!
    Oct 2013
    Canada
    Hi guys ! im new on this forum and i speak french. sorry for my english ! :P I want to know if someone here know how remplace both airbags on my Grand prix GP 2004. i had a little accident and both airbags deployed.. is someone here have a good video or good informations ill be very happy cuz i dont want to spend 3000$ ! Thx !!
  2. #2 Re: Someone know how to remplace both airbags ?!
    You will need to remove the dashboard cover to change the passengerside. The driverside is usually just the front of the wheel. Once that is done, a dealer or someone with the proper tool can reset the module for them.
  3. #3 Re: Someone know how to remplace both airbags ?!
    Oct 2013
    Canada
    ok Thx for the informations !! some ppl said i have to change the whole dash assembly... is that true ?!?
  4. #4 Re: Someone know how to remplace both airbags ?!
    I am not sure. I've only taken apart 97-03 and the airbag is under the dash board pad. The pad might need to be changed as well on your year.
  5. #5 Re: Someone know how to remplace both airbags ?!
    Oct 2013
    Canada
    do you think this is this part ?! http://www.ebay.com/itm/2004-2005-Po...40022b&vxp=mtr
    and some ppl speak about the belts too.. Thx for the fast answers man !!
  6. #6 Re: Someone know how to remplace both airbags ?!
    GTP Level Member simbah's Avatar
    Lala land
    Don't be a fool. I think that $3000 is a very sound sound investment to have the airbags replaced safely and properly. How much is your life worth to you anyhow. $3000 is nothing compared to being dead because you decided to replace the airbags yourself and they either deployed at an inadvertant time or worse yet didn't deploy when you needed them to and now you are dead or at the least seriously injured rather than spend a little cash to insure your safety and the safety of those who travel with you.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  7. #7 Re: Someone know how to remplace both airbags ?!
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    ^^^They bolt in,plug in,and a qualified shop resets the module (or tells you something is bad) not much to screw up.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  8. #8 Re: Someone know how to remplace both airbags ?!
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    I also believe a 04 doesn't have the pop out pad like the 97-03 so that would need the dash pad needs replaced also
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  9. #9 Re: Someone know how to remplace both airbags ?!
    Apr 2009
    Elkhart
    u will have to replace both seat belts both air bags most of the time the clock spring gets melted and also the derm or the air bag module will have to be replaced as it is a one time use only for safety reasons might also have to replace the belt buckles due to them having pre tensioners in them
  10. #10 Re: Someone know how to remplace both airbags ?!
    gardner,mass
    Racecars dont have airbags..........
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  11. #11 Re: Someone know how to remplace both airbags ?!
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    You will need to replace both the passenger side air bag module and the instrument trim panel. The list price on the passenger side air bag is $750, depending on installed options, the instrument trim panel is a bit north of a grand.
    It's quite possible that the pretensioners in the seat belts have fired. You'll need to replace them if they have.
  1. Replacing rear speakers w/monsoon and airbags
    By bjm306 in forum Audio, Security & Visual Electronics
    Last Post: 01-30-2013, 07:53 PM
  2. no airbags or radio controls
    By gtp239 in forum General Tech Discussion
    Last Post: 01-22-2011, 04:38 PM
  3. How do the airbags work in an >04 Grand Prix?
    By jimbob3000 in forum Off Topic Discussion
    Last Post: 06-17-2010, 10:14 AM
  4. Honda Recall-Exploding airbags
    By mystic231 in forum Off Topic Discussion
    Last Post: 07-31-2009, 07:50 PM
