Thread: Clock works when it wants to
Results 1 to 4 of 4
  1. #1 Clock works when it wants to
    May 2012
    Jacksonville, Fl
    I have a stock 02 Grand Prix GT with the Bose radio system. The clock works when it decides I need to know what time it is or what radio station I am listening to, otherwise, it is blank. It appears that the clock is a seperate unit in the upper left corner of the face of the radio. Is it possible to pop it out and replace it? Or can someone tell me what wire I need to check to tighten up since it appears something is loose? Thanks in advance for any assistance. Bill
  2. #2 Re: Clock works when it wants to
    Sounds like you have a loose solder somewhere. If your comfortable with pulling it apart see if you can see some loose wires or anything somewhere
  3. #3 Re: Clock works when it wants to
    May 2012
    Jacksonville, Fl
    still not working. Any additional suggestions ?
  4. #4 Re: Clock works when it wants to
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    My 2000 did the same thing,it was the factory bulb that had a bad connection.I was going to solder in an led bulb,but i hit a decent sized branch in the road one night and its worked great ever since...not joking.lol.If you can still see the time or station in the display when you shine a flashlight in it then its probly the bulbs connection.You can switch the display card out with one from a junkyard stereo, but chances of getting one with a blown light is pretty good.Its a common problem for the bulb to burn out in these.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  1. Clock spring
    By jpearsall187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 07:50 PM
  2. Its Like an Alarm Clock
    By csssaint12 in forum Off Topic Discussion
    Last Post: 12-24-2010, 01:34 PM
  3. GP alarm clock
    By 99prixgt in forum Off Topic Discussion
    Last Post: 12-23-2009, 10:56 AM
  4. Clock Went Blank
    By Latdogg in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2009, 02:10 PM
  5. Clock.
    By Dohner in forum Forum Bugs/Suggestions
    Last Post: 02-13-2009, 10:41 PM
