Thread: Led trunk light
Results 1 to 8 of 8
  1. #1 Led trunk light
    GTP Level Member Grandprix202's Avatar
    Apr 2013
    Fowlerville
    I got a led strip for my trunk in my 04 gt because the regular bulb wasn't very bright. After I cut the wire and spliced it the led strip is on but it's not bright at all. It looks to be about 25% I grabbed another strip I had laying around and I tried it and same thing... What's going in here
  2. #2 Re: Led trunk light
    Banned
    Oct 2013
    Moorhead, MN
    Resistance or a bad ground.
  3. #3 Re: Led trunk light
    Banned
    Oct 2013
    Moorhead, MN
    Check your grounds, make sure they're in unpainted surfaces.
  4. #4 Re: Led trunk light
    Jul 2010
    Coquitlam,BC,Canada
    Sure does sound like a bad ground. Had the same problem when I first installed mine.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Led trunk light
    Apr 2013
    Fowlerville
    What ground did you have to look at... Where is it at?
    Sent from my Galaxy Nexus using Tapatalk 4
    Representing all the N/A out there. Fastest stock N/A you will ever come across.
  6. #6 Re: Led trunk light
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Grandprix202 View Post
    I just tapped into the wiring at the stock light. I had an issue with the wiring at the trunk release on the lid; I could wiggle the plug and make the trunk light go on/off/dim. I snugged up the terminals in the plug (fixing the bad ground), and it has worked fine for over two years.
    My LED Trunk Light Install
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Led trunk light
    Apr 2013
    Fowlerville
    Quote Originally Posted by Bronco Boy View Post
    Yea me to I just snipped and spliced the wire going into the stock bulb... So I have to mess with the truck opening? Sorry I'm a little confused
  8. #8 Re: Led trunk light
    Jul 2010
    Coquitlam,BC,Canada
    Possibly. I had to, but I couldn't find any info on the matter so it may not be a "common issue".
    The BCM turns on the light when the trunk latch is opened; I believe the wires are red/black for the trunk light at the latch. Wiggle the plug to see if your light changes.
    If it does, there is your problem.
    If it doesn't, you have more work to do.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Trunk Light
    By MattF in forum Introductions/Noob Questions
    Last Post: 02-28-2013, 07:59 PM
  2. Trunk light
    By JmanGT in forum Off Topic Discussion
    Last Post: 10-20-2009, 06:57 PM
  3. Trunk light, do all GP's have them?
    By BlownBigBlock in forum Visual/Body Modifications
    Last Post: 09-11-2009, 01:18 AM
  4. Trunk Light?
    By Southern Yankee in forum General Tech Discussion
    Last Post: 04-01-2009, 09:58 PM
