Thread: 2001 fog lights not working
Results 1 to 20 of 24
  1. #1 2001 fog lights not working
    Jan 2013
    Tolono IL
    i have tryed everything i can think of to get these fog lights to work and still nothing. the light on the switch lights up but no light outside the fog light. i have checked all the 10amp fuses and all them look good. any suggestions would be appreciated
  2. #2 Re: 2001 fog lights not working
    St. Louis
    Stupid question, do you have the HIDs wired up properly? I know on the ones I bought from a member here they didn't work until I flipped the 2 wires at the harness and then walla- let there be light.
    No idea if my fog switch was lighting up when they weren't on as my switch led has been burnt out since I got the car lol...
  3. #3 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    they dont even work when i hooked up the stock lights. i wonder if i burnt something up.
  4. #4 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    wait lol stupid question i found it
  5. #5 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    where is the fuse for it under the hood?
  6. #6 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    i put a new fuse in and it blew again...could it be a bad relay?
  7. #7 Re: 2001 fog lights not working
    St. Louis
    Could be. Did the fuse pop again with the stock fogs installed? If so, then I'd suspect you killed the relay or fried a wire somewhere and it's grounding out when power hits it. Might want to try and trace the wires back from each fog and see if you notice any melted plastic.
  8. #8 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    no it didnt and i checked all the wires and they are all good. i think its the relay and i was looking around on here and some people built their own relay? i wanna buy a new one and put it in and see if that does it but if that one dies again i think i might make my own like some people on here
  9. #9 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    just a quick update on them. so i was bored at home and i checked the relays i took the horn relay out and put it in the fog lights one and the fog lights one in the horn one. honked the horn and it worked fine. so i know the relay isnt bad. what else could be the problem on this!! i cant figure anything out with this! it keeps blowing fuses and i have used all the spares that are 10amp that came with the car and now i gotta go buy more. is there any way i could set up a bigger fuse maybe without the chance of catching something on fire
  10. #10 Re: 2001 fog lights not working
    St. Louis
    No, don't install a bigger fuse or you may have more issues than just the fogs not working. Time to trace some wiring and look for the short would be my next step. Something has to be tripping the fuse if it pops right away.
    FYI- Hit up a junkyard for something else you need and "aquire" a bunch of 10 amp fuses while there. I haven't bought fuses for any car I own or have worked on for the last 10+ years this way.
  11. #11 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    lol the nearest junk yard where u can pull items is like 30 miles away. i might go here soon to get some parts for my girlfriends car. i think i might just get it then
  12. #12 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    also what if its just the HID blowing the fogs? how would i fix that so they dont blow?
  13. #13 Re: 2001 fog lights not working
    Jul 2010
    Coquitlam,BC,Canada
    You have a short somewhere in the wiring.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    is there any particular spot thats pretty common or just gotta trace all the wires?
  15. #15 Re: 2001 fog lights not working
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by lilmidge12 View Post
    .....just gotta trace all the wires?
    Yes.
    I would check all connectors and bulbs first, and if all is well, move to the wiring.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  16. #16 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    alright ima have to do that. is there a easy way to doing this? and what should i be looking for?
  17. #17 Re: 2001 fog lights not working
    Jul 2010
    Coquitlam,BC,Canada
    No.
    .....and what should i be looking for?
    Broken/chafed wire, loose/bad connection, corrosion etc. Could take minutes, or could take hours. A voltmeter would be helpful.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #18 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    figured....well tommrow i gonna do it and see if i can find anything
  19. #19 Re: 2001 fog lights not working
    Jan 2013
    Tolono IL
    so i finally checked to see if my wiring was fryed and i looked at every inch of the wire and it wasnt fryed at all it looked perfect. so i hooked the HID's up in a friends car and it blew his fuse too. Any suggestions on how i can fix this like rewiring the foglights to a bigger fuse with a bigger wire?
  20. #20 Re: 2001 fog lights not working
    Jul 2010
    Coquitlam,BC,Canada
    You have a short in your HID's. Do not go bigger wire or fuse; that is a fire waiting to happen.
    Get a fused power supply and plug your HID's in part by part; harness, then a ballast, then the second ballast, then a bulb, then the second bulb. Eventually you will find the "pop" and your problem..
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. dic lights,radio lights hud display..not working but is it a big deal if they dont?
    By wolfgang in forum Audio, Security & Visual Electronics
    Last Post: 05-21-2013, 07:34 AM
  2. 2001 GP GT Fog Lights not working
    By ST0NGE in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2013, 02:13 PM
  3. Help REAR TAIL LIGHTS NOT WORKING, BUT BRAKE LIGHTS WORK.
    By shihiran in forum General Tech Discussion
    Last Post: 10-21-2012, 02:35 PM
  4. 2001 GTP - Replacement rear tail lights and front head lights
    By zguy in forum General Grand Prix Discussion
    Last Post: 01-09-2012, 06:21 PM
  5. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
