I'm getting ready to install my Viper SST 5900...
Questions I have are these...
On the Relay Satellite wire (the one all the ignition wires go into). There is a green wire called the "Starter Anti-Grind/Starter Kill" it says to attach it to the "keyside starter wire". Do I NEED this? I read on another site for wiring you need a relay to run it right which I am not going to do unless I need it? Also I guess you need an add on for this? If I don't need it I'm just going to shorten up the wire..
On the same Relay Satellite wiring harness we have a orange wire, says to connect to the "Climate Control System" I understand what this is for but where is the best place to tap this one in?
This is cross posted on CGP.
