Thread: '04 GTP climate control backlights
Results 1 to 4 of 4
  1. #1 '04 GTP climate control backlights
    Sep 2013
    Georgia
    Half of the back lights in my climate control module are burned out. I've had the assembly out in my hands, and taken the back cover off, but I don't see how to get to the front of the PCB. Do the knobs pull off? I pulled pretty hard with no luck, and wanted to check before I broke something off.
    Thanks!
  2. #2 Re: '04 GTP climate control backlights
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Quote Originally Posted by bradlandrum View Post
    Thanks!
    According to the parts catalog, those bulbs are not serviced separately.
    I've got one burned out in my $250 control. Let me know if you figure out how to replace them without f'ing the board up.
  3. #3 Re: '04 GTP climate control backlights
    Sep 2013
    Georgia
    I don't think I'll have a problem replacing the bulbs once I can get to the front of the circuit board. I'm sure I can find a bulb somewhere that will fit, just want to be sure I don't break the whole assembly trying to get it apart.
  4. #4 Re: '04 GTP climate control backlights
    Donating Users
    Aug 2013
    Michigan, USA
    It's probably the same as radio bulb replacement. I haven't tried mine yet but I do have a dark spot on the far left side. Check the knob for hidden screw that may lock the knob onto the shaft. Then try to pull it out.
    I'd experiment but I don't have a spare to play with and I like having working A/C while driving.
  1. climate control
    By gtcoup in forum Off Topic Discussion
    Last Post: 12-19-2010, 11:04 PM
  2. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  3. climate control
    Last Post: 01-27-2009, 09:10 PM
