Thread: Sub and amp
Results 1 to 12 of 12
  1. #1 Sub and amp
    Aug 2013
    ny
    Ok havnt don this before. Can't b hard. I wired many head units. I spend my time on motors not sound systems. I bought my 97 gp and I see the owner before me had a system in it. I see the power cable with no fuse. Ik I gota put that in. in the dash ivsee a red and black RCA cable yes the ends are that color. I assume that goes in back my deck ? I then see a single blue wire. mine you all 3 run to my trunk . I assume that blue wire is for remote wire on deck?
  2. #2 Re: Sub and amp
    GTP Level Member simbah's Avatar
    Lala land
    Yes, now just finish with the other missing parts, amp, sub, speaker wire, ground, and you have a system.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: Sub and amp
    Aug 2013
    ny
    With the amp and sub in will my speakers in the car only do high and mids? Cus the 6x9s rattle as of now
  4. #4 Re: Sub and amp
    Lala land
    Well that is a question up for discussion. As they are wired your speakers are full range, meaning that there is no crossover to limit high or low frequencies. Without knowing the specifics of your speakers I couldn't begin to tell you what frequencies your speakers are going to play. Most likely 50-15khz.
  5. #5 Re: Sub and amp
    Aug 2013
    ny
    Speakers are stock gp.
  6. #6 Re: Sub and amp
    i added a sub and amp to my stock radio, it adds a nice thump and makes the whole system a bit louder as well. its just enough to keep me happy sound wise.
    i used a single 12 inch sub, and a 500 watt amp.
    i did install new speakers as my stock ones were shot.
  7. #7 Re: Sub and amp
    Aug 2013
    ny
    So it is a crossover that keeps the lows away from the speakers?
  8. #8 Re: Sub and amp
    Aug 2013
    ny
    Did a lil reading. Some decks have high pass filters on them. And if not i can turn the bass all the way down and play with amp output just to balance it all out
  9. #9 Re: Sub and amp
    Aug 2013
    ny
    Looked at my Manuel itbdoes have filter to send signals under Certain hz. Only to the sub
  10. #10 Re: Sub and amp
    GTX Level Member Bills1997GTP's Avatar
    Oct 2012
    Philadelphia
    It keeps the lows away from everything but the subs, personally I like it better, it makes everything a lot louder and clearer
    2004 Grand Prix GTP 150,000 " The New Edition "
  11. #11 Re: Sub and amp
    Lala land
    Your amp may have a low pass filter built in but that does no good to the speakers because the amp is not powering the speakers only the sub. So you are sending a full range signal to your full range speakers, they will play what ever frequencies they will play. If you have a filter built into your headunit that will help to eliminate the lower frequencies from being played. I would set that at 100hz minimum and see how you like it and adjust to fit your needs.
  12. #12 Re: Sub and amp
    Aug 2013
    ny
    Yes just as I said. My hu does
amp
