I disabled my drls last fall just by pulling the drl fuse. But now it started acting up and I have no dash back lights when I manually flip the headlights on. Could the switch be going bad or what??
Nope only ones I'm having issues with are the one that light up red at night
I had no probs beforetoo. Like which fuses? I will look closer tonight but when I looked before there was nothing obvious to check
Ok i will try. And they work fine when I put the fuse bAck in but when I pull it and flip them on they come on for a second and then to out like they are being shorted. They wouldn't do this cuz I upgraded to the digital Dic?
Mine was short on big fuse block under hood. I lifted it up and. Bam. It started working. The wire pulled out from behind fuse block just a little.
