Thread: DDM HID harness, check your fuse
Results 1 to 6 of 6
ItHurtz DDM HID harness, check your... 05-07-2013, 07:04 PM
tc300 Re: DDM HID harness, check... 05-12-2013, 05:59 AM
stealthee Re: DDM HID harness, check... 05-12-2013, 10:14 AM
ItHurtz Re: DDM HID harness, check... 05-12-2013, 04:04 PM
stealthee Re: DDM HID harness, check... 05-12-2013, 04:18 PM
LS2 BLAZER Re: DDM HID harness, check... 05-12-2013, 04:24 PM
  1. #1 DDM HID harness, check your fuse
    Antioch, IL
    If you have DDM's wire harness check your inline fuse, they are not waterproof and over time cause this (see pic)
    Symptoms are delayed ignition, sometimes ignite sometimes dont, and then hid's stop working. Its not GP specific it happens to anyone with this harness. Solution? Get a waterproof fuse case and you will be golden. I got lucky and was aple to put in another fuse, I have seen some melt the entire case.
    Uploaded with ImageShack.us
    2009 Challenger SRT8
    Expert at being gay.
  2. #2 Re: DDM HID harness, check your fuse
    GTP Level Member
    springfield IL
    Interesting........
  3. #3 Re: DDM HID harness, check your fuse
    SWPA
    That isn't necessarily caused from a non waterproof case. I have had similar issues happen on an amp. It just depends on the situation, but basically the fuse melts before it pops. That doesn't have to be caused by water.
  4. #4 Re: DDM HID harness, check your fuse
    Antioch, IL
    This issue is more than likely water. You can google it, alot of people have switched to waterproof cases and havent had a issue come back.
  5. #5 Re: DDM HID harness, check your fuse
    SWPA
    Its more than likely not water and just a crappy fuse holder.
  6. #6 Re: DDM HID harness, check your fuse
    Donating Users LS2 BLAZER's Avatar
    Lorain, OH
    this happens across the board on any brand.. i have VVME HID's with a relay harness in my SS and my fuse just melted itself as well (held strong for 3 years)... $9 later, i was back in action...
    2001 Grand Prix GT - stock (for now )
    2007 Trailblazer SS - back under the knife , motor #4 on the way
  1. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  2. What fuse is it?
    By asite57 in forum General Tech Discussion
    Last Post: 12-02-2011, 09:46 PM
  3. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  4. HID fuse
    By 04GTPTyler in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 09:56 AM
