Thread: Remote Start Install Questions...
Results 1 to 2 of 2
Incomudrox Remote Start Install... 11-22-2008, 11:05 PM
Burbman Re: Remote Start Install... 12-02-2008, 02:19 PM
  1. #1 Remote Start Install Questions...
    SE Level Member Incomudrox's Avatar
    New Holland, PA
    I'm getting ready to install my Viper SST 5900...
    Questions I have are these...
    On the Relay Satellite wire (the one all the ignition wires go into). There is a green wire called the "Starter Anti-Grind/Starter Kill" it says to attach it to the "keyside starter wire". Do I NEED this? I read on another site for wiring you need a relay to run it right which I am not going to do unless I need it? Also I guess you need an add on for this? If I don't need it I'm just going to shorten up the wire..
    On the same Relay Satellite wiring harness we have a orange wire, says to connect to the "Climate Control System" I understand what this is for but where is the best place to tap this one in?
    This is cross posted on CGP.
  2. #2 Re: Remote Start Install Questions...
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Try over at the 12 Volt Forum. It's a forun for professional car electronics aftermarket installers, there's usually somebody who has already doen this install that can help you with the tech details.
  1. Remote start options
    By xerxescct in forum General Tech Discussion
    Last Post: 10-31-2009, 08:14 AM
  2. Remote start on GP
    By Freebeer187 in forum General Tech Discussion
    Last Post: 04-12-2009, 07:30 PM
  3. PK III and Remote start...auto shut down grrr
    By mongo in forum General Tech Discussion
    Last Post: 08-07-2008, 06:37 PM
  4. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
  5. want to add shock sensor to existing car security/remote start
    By fst in forum General Tech Discussion
    Last Post: 01-11-2008, 06:55 PM
