Thread: Help with aftermarket radio!!!
Results 1 to 16 of 16
  1. #1 Help with aftermarket radio!!!
    Apr 2013
    Denison
    When I got my 05 grand prix, it did not have a radio in it at all. I bought an aftermarket radio and took it to best buy. They installed the radio, and then afterwards told me that the insturment gauges would not work because the computer in the car was searching for the factory radio. I don't understand why the gauges worked without a radio in it at all, but then they put one in for me and all the sudden none of my gauges work properly. You can just be driving down the road and all of the sudden the speedometer, rpms, temperature, and gas all go to zero and won't go back until you restart the car. They said if I buy a factory radio they can wire the radio to the trunk and this will fix the problem.
    My questions:
    1. Is this true?
    2. If it is true, can I buy a factory radio that doesn't work or does it have to be a working factory radio?
  2. #2 Re: Help with aftermarket radio!!!
    Best buy guys are morons.
    The only thing that would not work with a aftermarket radio is going to be the calendar feature on the DIC you can keep features like door chimes,onstar and steering wheel controls if you get the correct harness/module.
    And what do you mean by gauges?
    04 Comp G.
  3. #3 Re: Help with aftermarket radio!!!
    Apr 2013
    Denison
    I mean the speedometer and the temperature gauges and the gas gauge and the RPMs. They all go to zero like they aren't working. They won't go back to normal unless you restart the car. it didn't do this before they put the radio in. If the computer was searching for a radio, why would it not have done this before when there was no radio at all?
  4. #4 Re: Help with aftermarket radio!!!
    Apr 2013
    Denison
    Even the low fuel warning on the little computer screen comes on, even though I know I have gas.
  5. #5 Re: Help with aftermarket radio!!!
    Jul 2011
    Midwest USA
    Look up GMOS-014. It's a wire harness that is required for any aftermarket radios on the 04+ cars. (there's a couple others out there, but that's what we use at the shop here all the time and have always had good luck with it.) If the Best Buy guys didn't put one in or put in a non-working one (it's been known to happen), it'll cause all sorts of random issues with those cars.
    My guess is the Best Buy guys put in the wrong harness (or a non-working one) and when they couldn't get it to work made that up as an excuse to get you out the door. Aftermarket radios will not cause those issues if installed correctly with the proper wire harness.
    Why post when you can lurk?
  6. #6 Re: Help with aftermarket radio!!!
    Apr 2013
    Denison
    Quote Originally Posted by Linus M View Post
    Look up GMOS-01. It's a wire harness that is required for any aftermarket radios on the 04+ cars. (there's a couple others out there, but that's what we use at the shop here all the time and have always had good luck with it.) If the Best Buy guys didn't put one in or put in a non-working one (it's been known to happen), it'll cause all sorts of random issues with those cars.
    So, if he replaces whatever he used with one of those it should start working again? I'm just frustrated, I can't drive around without working gauges!
  7. #7 Re: Help with aftermarket radio!!!
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    First off the radio interface modules for the 04+ grand prixs DO NOT WORK PROPERLY.
    they will for sure 100% cause data communication errors.
    Pull that **** out and just hook the red accessory off the aftermarket radio to the wiper fuse (easiest access for a rap circuit to turn the radio on) or any accessory/ignition wire.
    Without the module you will lose chime, onstar and the date in your dic that's it. This is assuming you don't have monsoon, os04 is required for monsoon and the os01 will not work properly
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  8. #8 Re: Help with aftermarket radio!!!
    Apr 2013
    Denison
    Quote Originally Posted by rperry435 View Post
    Thanks. What is monsoon? My radio is a Kenwood!
  9. #9 Re: Help with aftermarket radio!!!
    Oct 2011
    MI
    Linus is right the gm os01 is the only good module although NOT needed unless you want to retain the onstar and chime..its Made by axxess I believe.
    Schoche or however u spell it are the worst
    And there is no "searching" for the radio it's either there and communicating or its just not there. It will not create any adverse problems not being there
  10. #10 Re: Help with aftermarket radio!!!
    Apr 2013
    Denison
    I don't care about maintaining anything except for my speedometer, gas gauge, RMP and temperature gauge!
  11. #11 Re: Help with aftermarket radio!!!
    Oct 2011
    MI
    Do you have a speaker In the center of the dash?
  12. #12 Re: Help with aftermarket radio!!!
    Apr 2013
    Denison
    No. I have two speakers on the front doors that don't work, they are factory speakers. The car came with two aftermarket speakers in the back that do work.
  13. #13 Re: Help with aftermarket radio!!!
    Oct 2011
    MI
    Ok well if no speaker on the dash your grand prix didn't come with the factory upgraded monsoon system.
    You don't need any module. Remove the module in there and hook up the accessory off the radio to the wiper fuse. That's probably the easiest for you.
  14. #14 Re: Help with aftermarket radio!!!
    Apr 2013
    Denison
    What is a module?
  15. #15 Re: Help with aftermarket radio!!!
    Aug 2013
    Miami
    im kind of lost im about to hook up a aftermarket radio and i do hve the speaker in the middle i tried to hook up the stock radio and i notice no sound wires r cut from the factory amp but i had power no radio station came on i put i cd in it took it but didnt play so any help fellas
  16. #16 Re: Help with aftermarket radio!!!
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Sounds like you have a Monsoon system in your car. They are trickier to hook up due to an amp being integrated in and more speakers. Hopefully someone with more knowledge than me will chime in.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  1. Aftermarket radio with HUD
    By YZ250rider in forum Audio, Security & Visual Electronics
    Last Post: 08-02-2012, 04:04 PM
  2. aftermarket radio
    By RedGrandprixgt53 in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2012, 12:46 PM
  3. Aftermarket radio in 08 GP?
    By bziggy58 in forum Audio, Security & Visual Electronics
    Last Post: 09-13-2011, 02:15 PM
  4. help needed with aftermarket radio
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2011, 10:34 PM
  5. Aftermarket radio static?
    By pr0necr0 in forum Audio, Security & Visual Electronics
    Last Post: 05-25-2011, 10:52 PM
