Most of my window / door lock switches are burnt out, so I wanna swap them with LED. Anyone got a wiring diagram? Or pics of how you stuffed the resistors in there?
97-03? that conversion was a pain in the ass..
the headlight selector switch was worse..
taking it out causes the "key in ignition" noise to go off Constant
Thanks for posting magnus. I noticed the other day that my passenger front door lock switch was not illuminating. I removed it when I got home today and will be off to the electronics store tomorrow. If I can do the right door without hurting myself, I will tackle the left door.![]()
Looking good.
How did you remove the switch from the plastic piece?
There are plastic tabs holding the switch assembly to the plastic piece. Just pull them away from the switch
Look on the underside of the piece the button slides out through the bottom
magnus, what are the specs on the LED's you used?
I just got some that are:
- red super bright LED
- 2,000 mcd output
- 1.8V @ 20mA
- 15° Viewing angle
I used 1W, 680ohm resistor (couldn't find any 1/2W 680ohm), and they aren't as bright as I was hoping for.
It might be the angle, the stock bulbs point straight up, the led you have to kind of angle to the switch a bit, especially if your viewing angle is kinda narrow.
Ya, I am suspecting the angle also. I am going to finish the right switches and do a night comparison to the left side (stock).
