Thread: Big 3 upgrade help
Results 1 to 11 of 11
  1. #1 Big 3 upgrade help
    Aug 2012
    New York
    Okay guys I have searched on a few grand prix forums and have found nothing but hopefully someone here can help me... I ran the ground wires for the big 3(4 gauge) one to the strut tower and the other to a ground bolt on the alt. once I ran the power wire from the alt to the battery(4 gauge) and started the car it seemed like it was looping the power or something because it wouldn't turnover on the first click, it would take another click to turnover. I removed the power wire and it had no problem starting right away. Am I doing something wrong?
  2. #2 Re: Big 3 upgrade help
    Yoga city
    the ground needs to be connected to the battery, a ground needs to be onthe motor or alt case, and one from the alt power to the battery.
    and 4 gauge? really? go bigger bro.
  3. #3 Re: Big 3 upgrade help
    Aug 2012
    New York
    Quote Originally Posted by jteske88 View Post
    im not going any bigger than 4 gauge right now because theres no need for it. true 4 gauge wire is plently to handle the amount of power I need, I don't have a crazy system and anything bigger would be overkill.
  4. #4 Re: Big 3 upgrade help
    Dec 2012
    Hawai'i
    Quote Originally Posted by Leroyy View Post
    There's no such thing as overkill on wire size
    2002 Impala- SSC, AGX, 18" charger R/t rims w/8mm spacers, Magnaflow cat, U-bend delete, flowmaster 80 series crossflow, z28 tips, HAI, debadged, 35% tint, smoked headlights, full sound system
  5. #5 Re: Big 3 upgrade help
    you sure are.
    one wire from alt stud and bolt, to the battery pos, or the top of the fuse box bolt.
    a ground from the battery to the engine. back of the alt bracket is used a lot.
    and then a new ground from the engine to the body of the car.
    search, big 3 upgrade "grandprixforums" on google, then hit images.
  6. #6 Re: Big 3 upgrade help
  7. #7 Re: Big 3 upgrade help
    Aug 2012
    New York
    I did battery negative to alternator bracket, and then to the chassis. and from the alternator charging spot to the batt positive
  8. #8 Re: Big 3 upgrade help
    Arizona
    All 0 gauge here **** is cheap on ebay
  9. #9 Re: Big 3 upgrade help
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by 91parkave View Post
    Hell I got me 20 feet of zero gauge for 4 bucks a foot locally. Its not all that expensive and if our gonna do something...do it right. I also have all new battery terminal connectors that solder on. In my opinion and research I've done ya should go bigger wire and spend the extra couple bucks
  10. #10 Re: Big 3 upgrade help
    Dec 2012
    Hawai'i
    Even knu konceptz which is the biggest and best I've seen in person is like $4 a foot. Best bang for the buck is welding cable. Go to your local welding place and see. I bet it's like $2 a foot
  11. #11 Re: Big 3 upgrade help
    Arizona
    I got 20ft for 30 shipped
  1. HD Upgrade?
    By Speedy1973 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-22-2012, 08:38 PM
  2. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  3. looking to upgrade
    By mattcavalier in forum Introductions/Noob Questions
    Last Post: 01-28-2010, 09:25 AM
  4. First upgrade for GTP ?
    By MikeZirpola in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2009, 08:20 PM
  5. L26 upgrade
    By tod1d in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-27-2009, 12:33 PM
