Thread: Stereo installation in a 2003 GTP
Results 1 to 8 of 8
  1. #1 Stereo installation in a 2003 GTP
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Now, I know there are lots of posts about installing stereos in the '97 - '03 GPs, BUT.... there is so much confusion, I would like to attempt to get all the info into one thread. So, I am throwing out this question to those that have installed stereos in these vehicles. The variables about this install are: 1) WITHOUT OnStar or Bose, 2) WITHOUT OnStar, but With Bose 3 WITH OnStar and Bose, what is needed in way of wiring harnesses AND brackets. I have read that all that is needed is a simple plug with bare wires, or a wiring harness adapter kit. I have heard double dins need a bracket, and I have heard double dins need a "homemade" remedy. I have seen double dins that just fit behind the bezel and use a few pieces of plastic to fill the voids, and I have seen double dins that infringe on the heater controls below. So, what I am asking, is please post your installs, listing what you used and did to install your radio (as in what wiring did you need?). I am not so much concerned what your radio does, just what size (single or double din) If single din, was it a video unit, and did the video display go above or below the radio? Thanks to all who can help out.
  2. #2 Re: Stereo installation in a 2003 GTP
    SE Level Member black01gtx's Avatar
    May 2011
    fort wayne
    Can anyone put up some pictures of how they mounted their replacement speakers in a Bose equipped car? I'm redoing all the wiring to put in an aftermarket amp and speakers but i keep hearing that aftermarket speakers wont just bolt right in.
    owner of 2 3.8 forced induction vehicles
    2001 grand prix gtx
    1984 grand national
  3. #3 Re: Stereo installation in a 2003 GTP
    Mar 2013
    Manitoba, Canada
    Quote Originally Posted by black01gtx View Post
    Thankyou for hijacking my thread and changing the subject.
  4. #4 Re: Stereo installation in a 2003 GTP
    Mar 2013
    Manitoba, Canada
    So nobody has successfully installed a double din in their 2003ish Grand Prix? Someone has to of done this. Still wondering what harnesses you need to get this all done. I know about the steering wheel control harness, but am still confused if I need a simple wire harness to connect the head unit up to my Bose amp, or if I need one of the harnesses that has a module in it??
  5. #5 Re: Stereo installation in a 2003 GTP
    Dec 2010
    DMV
    Cut and fit. I have one in my car right now. I can snag you a pic in 15 if ya like
  6. #6 Re: Stereo installation in a 2003 GTP
    Dec 2010
    DMV
  7. #7 Re: Stereo installation in a 2003 GTP
    Mar 2013
    Manitoba, Canada
    Looks not bad, but did you need a simple adapter that just plugged into the stock vehicle wiring and then soldered the wire connections to your deck, or did you need one of the special adaptors with a module in it? Also, did your car have the Bose system in it?
  8. #8 Re: Stereo installation in a 2003 GTP
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    Metra is your friend. My 2005 took their GMOS-04 adapter plus the steering wheels control adapter. My car has the Monsoon amp and I've kept that as well as the stock speakers.
    Does the 2003 have a double DIN mount? You may consider getting a single DIN head unit with a motorized, pop out screen.
  1. HID Installation
    By silvermistgt2002 in forum Visual/Body Modifications
    Last Post: 12-26-2009, 01:39 AM
  2. 2003 GT vs 2003 mitsubishi eclipse GTS
    By kjohnson in forum Track Sessions and Kills
    Last Post: 04-01-2009, 11:27 AM
