Thread: What dash kit can I use for d-din?
Results 1 to 14 of 14
  1. #1 What dash kit can I use for d-din?
    Aug 2012
    Tukwila, Washington, United States
    I have this pioneer avh-p2400bt
    Which fits perfectly with out cutting anything.
    But there is space
    What dash kit should I use to cover that???
    Grand Prix gt 1999 v6 3.8L coupe.
  2. #2 Re: What dash kit can I use for d-din?
    SE Level Member darionmilton's Avatar
    Jun 2010
    Lansing, Michigan, United States
    You may have to make your own
    Sent from my SCH-I535 using Tapatalk 2
  3. #3 Re: What dash kit can I use for d-din?
    Make your own. Considering the 97-03 wasn't intended originally to have a double din you'll have to get custom. Get some ABS plastic sheets and a template made and use some plastic goop to bond it together...sand and then paint and it should blend in.
    04 Comp G.
  4. #4 Re: What dash kit can I use for d-din?
    Jul 2010
    Coquitlam,BC,Canada
    I seem to recall seeing somewhere that the Montanna or other mini-van one worked or could be made to work.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: What dash kit can I use for d-din?
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    go to home depot and get some plumbing strap.. works best.. use small 4 inch section and bend it into a 90* angle
    http://cds.a9t2h4q7.hwcdn.net/main/s...rge/C52410.jpg
    this is what it looks like
  6. #6 Re: What dash kit can I use for d-din?
    Aug 2012
    Thank you.
    Any more options?
  7. #7 Re: What dash kit can I use for d-din?
    Nov 2012
    Cincinnati
    no its your best bet.. ive done it on my car and never had an issue with it.. its the "custom" way lol
  8. #8 Re: What dash kit can I use for d-din?
    Aug 2012
    Ok I'll go try it. I hope the holes won't show.
    If you a photo somewhere it would be great. Otherwise don't bother, I'll figure it out.
    Btw what keeps it from moving inside ?
  9. #9 Re: What dash kit can I use for d-din?
    Nov 2012
    Cincinnati
    i actually just realized that your trying to cover the open area.. i thought you were trying to get the radio to stay in place..
  10. #10 Re: What dash kit can I use for d-din?
    Aug 2012
    Quote Originally Posted by mofford12 View Post
    So what do I need to get? I'm at Home Depot right now.
    I need to cover the space and keep it from moving
  11. #11 Re: What dash kit can I use for d-din?
    Nov 2012
    Cincinnati
    get the strap to keep from moving
  12. #12 Re: What dash kit can I use for d-din?
    Aug 2012
    Ok so here is what I did.
    I got at Home Depot
    The plumbing stap
    And a piece of plastic.
    I used the strap to push the DVD to the front.
    I cut 2 pieces of the plastic made holes for the screw with the solder iron and I coated it w a plasi dip.
    Then installed it
    Now it looks like this
    Not perfect but ill fix it to be tight.
  13. #13 Re: What dash kit can I use for d-din?
    Sep 2011
    Arkansas
    Sweet.. will copy.
    Sent from my A200 using Tapatalk HD
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  14. #14 Re: What dash kit can I use for d-din?
    Aug 2012
    Here a better one but still not centered lol. Who cares.
  1. dash mod
    By BBluelandyacht in forum Audio, Security & Visual Electronics
    Last Post: 02-19-2011, 05:42 PM
  2. dash
    By Chuckie in forum Introductions/Noob Questions
    Last Post: 01-21-2011, 11:20 PM
  3. Dash..
    By joshua_arndt in forum Visual/Body Modifications
    Last Post: 03-18-2010, 08:47 AM
  4. What do you use on your dash?
    By gdbyrd in forum Detailing Tips and Tricks
    Last Post: 05-02-2009, 01:37 AM
