Thread: Amp question
Results 1 to 12 of 12
MattF Amp question 03-15-2013, 02:13 PM
Scottydoggs Re: Amp question 03-15-2013, 04:30 PM
Fatboy501 Re: Amp question 03-16-2013, 02:20 AM
MattF Re: Amp question 03-16-2013, 02:30 AM
Fatboy501 Re: Amp question 03-16-2013, 03:08 AM
Scottydoggs Re: Amp question 03-16-2013, 09:13 AM
MattF Re: Amp question 03-16-2013, 01:14 PM
Scottydoggs Re: Amp question 03-16-2013, 01:23 PM
MattF Re: Amp question 03-16-2013, 02:36 PM
Scottydoggs Re: Amp question 03-16-2013, 02:43 PM
MattF Re: Amp question 03-16-2013, 03:48 PM
Scottydoggs Re: Amp question 03-16-2013, 04:03 PM
  1. #1 Amp question
    Sep 2012
    Cedar Rapids, Iowa
    Do you have to connect all the speakers in your car to an amp you are usin for subs?
  2. #2 Re: Amp question
    if its just for a sub and amp, all you do is solder a lever output converter from a rear speaker, then run the rca cables from the level out put to the amp.
    i just replaced my speakers, and added a single 12 sub and amp to my radio, the sound is night and day.
  3. #3 Re: Amp question
    Sep 2011
    Arkansas
    No. Only connect the speaker/s you wish to amplify. The above suggestion is a good one if you're sticking with the stock stereo.
    Sent from my A200 using Tapatalk HD
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  4. #4 Re: Amp question
    Sep 2012
    Cedar Rapids, Iowa
    What's a level output converter?
  5. #5 Re: Amp question
    Sep 2011
    Arkansas
    Line output converter. Basically allows RCA connections for amplifiers by simply tapping a stock speaker wire. A nice solution for those who wish to retain their stock head units.
  6. #6 Re: Amp question
  7. #7 Re: Amp question
    Sep 2012
    Cedar Rapids, Iowa
    So if I already have a aftermarket head unit with RCA connectors I don't
    need to buy this convertor?
  8. #8 Re: Amp question
    correct. but you need rca cables long enough to reach the hu to the amp. most amp install kits have this included, the power wire, amp signal wire, and rca cables, for around 20 and up.
    im not sure how other guys got power to the trunk, but i went off the fuse box bolt, took the cowl off, and in the left corner drilled a hole, fed the wire in and it dropped under the dash, then i ran it along the side of the carpet, took the back seal out and run it under the side of the seat to the trunk.
  9. #9 Re: Amp question
    Sep 2012
    Cedar Rapids, Iowa
    Okay. And finally, to connect the amp the subs you use the Speaker out connectors? And what if im wiring in two subs
  10. #10 Re: Amp question
    if your amp is a 2 ch amp, most are at least that much, you run out put wire off the amp to each sub. aka left and right.
    search you tube, theres a bunch of vids showing how to wire all this up. its pretty simple as i always feared this crap myself, till i researched it, and then did it. pretty simple for the most part.
  11. #11 Re: Amp question
    Sep 2012
    Cedar Rapids, Iowa
    I pretty much understand it now. So all I need to wire to the amp is power from the battery, a ground, RCA from the stereo and a control wire from the battery
  12. #12 Re: Amp question
    your radio may have a amp signal wire on it already, read your HU manual for that. if not, i used a add a fuse to the wiper fuse for the amp signal wire. if the signal wire's power stays on with the key off, the amp will stay on all the time. and kill your battery.
    that being said, some amps need a different signal sent to them to turn on. a simple 12 volt line wont turn some on.
    and yes, it sounds like you got it all figured out now.
  1. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  2. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  3. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  4. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
