Thread: 2003 GTP radio question
Results 1 to 6 of 6
  1. #1 2003 GTP radio question
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Would the following radio be a plug and play exercise into my 2003 GTP (with steering wheel controls)? I presently have the Bose CD radio system with just the treble and base on the head unit, and the amp in the trunk. 94-03 Pontiac Firebird Sunfire Trans Am Grand Prix Grand Am Radio Cd 09390772 | eBay Then.... could I add the unit that allows me to hook up an IPod utilizing the "AUX" button on the deck ( I do NOT have a 6 disc changer)?
  2. #2 Re: 2003 GTP radio question
    if you have a bose you want to make sure the new radio is also a bose radio.
    for the aux port you can do this mod to the radio, i did it to my regal radio and another member did it as well to a gp radio, mines a regal radio, so with some reading you cane figure it out, it also only cost 5 bucks or less total in parts if you already have a soldering iron, and solder and shrink tubes. 3 bucks for the aux port, and 90 cents for a cat 9 wire at home depot, i got like 3 feet, more then enough.
    the solder, you want to use flux core solder, 5 bucks, the tubes and iron can be gotten at harbor freight for less then ten bucks.
    How you can add an aux input/mp3 player without an adapter - LS1TECH
  3. #3 Re: 2003 GTP radio question
    Wont be plug and play.
    That looks like a bonneville radio from 2000+.
  4. #4 Re: 2003 GTP radio question
    Mar 2013
    Manitoba, Canada
    Well, that is definitely an excellent way to utilize the existing radio. Since I was an electronics Technician in the military, soldering like that would be no problem. However, I was hoping for a "plug and play" solution, and am debating on changing my head unit for one with the cd/aux button, or installing an aftermarket head unit. I just don't want to loose all the dings and things that run through the factory radio.
  5. #5 Re: 2003 GTP radio question
    they sell a harness that retains the steering wheel controls and all the bells and whistles as it was stock. just not cheap.
    i just replaced all 4 speakers in my car, still got the stock radio, and the sound is like day and night, i bet its easily twice as loud as it used to be. then i added a 12 inch sub and a 500 watt amp. the sub woofer over powers the radio, so i have it turned down under half so if matches the radios max level. i must say, its just enough to keep me happy. the sub fills in a lot of sound.
  6. #6 Re: 2003 GTP radio question
    Mar 2013
    Manitoba, Canada
    Okay, now.... what are my options if I want to go to an aftermarket double din DVD player, possibly with GPS in it, and the ability to hook up a reverse camera, and..... retain the steering wheel controls?
  1. 2003 GP SE Question
    By rynotheman in forum General Grand Prix Discussion
    Last Post: 05-03-2012, 07:46 PM
