Thread: Aftermarket deck with GMOS 100, NO SWC
Results 1 to 8 of 8
  1. #1 Aftermarket deck with GMOS 100, NO SWC
    SE Level Member mckillin's Avatar
    Ontario, Canada
    Hey guys,
    I have a 2004 Grand Prix GTP w/monsoon & swc... Was sold the GMOS-100...
    Head unit - Kenwood DDX319
    I have it all wired up, amp works, chimes work, onstar works but no SWC..
    I've tried the auto/manual instructions for setup and can't get it to work.. At one point I had something, but the controls were all the wrong buttons, tried again and lost it all.. Very fustrating.. Wondering if anyone else has ran into this and if they have any advice or help would be great... I really miss my SWC..
    Thanks
  2. #2 Re: Aftermarket deck with GMOS 100, NO SWC
    Indianapolis
    you need another $100 adapter for that too, the first adapter only works for the chimes
  3. #3 Re: Aftermarket deck with GMOS 100, NO SWC
    Ontario, Canada
    I wanted to keep door chimes, amp and SWC and I was sold this, obviously oversold but I alreaady figured that out... I just want to get this thing working 100%
  4. #4 Re: Aftermarket deck with GMOS 100, NO SWC
    Ontario, Canada
    2000-UP General Motors Amplified/Non-amplified/Steering wheel control interface
    • Covers Class 2/LAN 29/Lan 11 vehicles.
    • Provides accessory (12 volt 10 amp).
    • Retains R.A.P. (Retained Accessory Power.
    • Used in amplified or non-amplified systems.
    • Retains all warning chimes.
    • Provides NAV outputs (Parking Brake/Reverse/Mute/V.S.S.).
    • Built in ASWC (steering wheel control interface).
    • Retains OnStar/OE Bluetooth.
    • Adjustable volume for chimes and OnStar.
    • High level or RCA level input.
    • USB updatable.
    • Retains balance and fade.
    • Retains factory back up camera.
    • Retains RSE (rear seat entertainment).
    • Retains OE satellite (pending it is not built into the radio).
  5. #5 Re: Aftermarket deck with GMOS 100, NO SWC
    GTP Level Member simbah's Avatar
    Lala land
    Here's what you may need to do, On pin A6( should be a purple wire) of the factory wiring harness ( the larger plug) you need to apply 12v signal, tap into the red wire of the aftermarket radio wire, so that there is power going to the steering wheel controls, then the GMOS-100 will be able to read the switches.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  6. #6 Re: Aftermarket deck with GMOS 100, NO SWC
    Ontario, Canada
    hey simbah i just tried that and still unsuccessful... having a hard time getting the blinkin LED to even work... key on, wait 20 seconds, hold volume down for 30 second and blinkin LED came a few times now its not lol very fustrating indeed..
  7. #7 Re: Aftermarket deck with GMOS 100, NO SWC
    Feb 2009
    Virginia
    Wish I could help. It's always been a PITA unless you had a direct plug n' play swc controller. I know my alpine was that way. Most use the IR though and you need direct line of sight.
    In case you want to go another way, here ya go...
    http://www.pac-audio.com/productSear...&CategoryId=29
    11 is louder than 10!
  8. #8 Re: Aftermarket deck with GMOS 100, NO SWC
    Ontario, Canada
    Hmmm... ya I have invested about $250 into this gmos and just wish it would all work but I am reading numerous problems with the SWC especially my Gmos100-kenwood :S
    Would i be able to run that adapter for SWC and the gmos for the rest without issues, seems like a long shot but haha
  1. DIC Funtions after Installing Aftermarket Deck
    By extreme in forum Audio, Security & Visual Electronics
    Last Post: 09-08-2012, 04:05 PM
  2. stock deck vs aftermarket replacement advice
    By NAC in forum Audio, Security & Visual Electronics
    Last Post: 08-24-2012, 07:59 PM
  3. Hooking up Aftermarket Deck in a '03 with Bose factory system/Amp
    By Kahn in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 10:49 AM
  4. Installing a aftermarket deck on a Bose system.
    By Pontiacman76 in forum Audio, Security & Visual Electronics
    Last Post: 09-07-2011, 09:19 AM
  5. aftermarket deck
    By whitegtp in forum Audio, Security & Visual Electronics
    Last Post: 07-21-2009, 09:20 PM
