Thread: Amp/speaker question
Results 1 to 3 of 3
  1. #1 Amp/speaker question
    Jersey
    I was wondering can i use a 4 channel amp to power to subs? The subs are 500 rms each and the 4 channel amp can run 400x2 bridged. Also, i've heard instead of making adapters to fit 6.5 speakers in the front.....you can just take the plastic baffle out and screw the speaker to the metal part. Is that true or its too good to be true because im getting ear fatigue with 5.25 speakers smh. Thanks
  2. #2 Re: Amp/speaker question
    Dec 2012
    Hawai'i
    Yeah you can hook the amp up. Make sure is 400 rms and not peak and a Lpf would be nice. Screwing to the metal is a horrible idea. With my 6.5's I just used the outer grill peice, flipped it upside down, screwed it to the plastic pod and then screwed the speaker to it. If anything make or have someone make a thin spacer. It's not hard at all and only takes like 2 min to make
  3. #3 Re: Amp/speaker question
    Feb 2009
    Virginia
    Doesn't matter how much power your amp makes if you're using them for the sub. It really just depends on if you like the results.
    First step in helping that ear fatigue is building your doors. Here's a good link...
    Simple, cheap, and effective door treatments - DIYMA Car Audio Forum
    11 is louder than 10!
  1. Monsoon System - What ohm speaker do I need for the center dash speaker?
    By Schmitty in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2011, 07:01 AM
  2. 97 gtp door speaker question
    By SarasotaGTP in forum Audio, Security & Visual Electronics
    Last Post: 12-06-2011, 08:44 AM
  3. Speaker system question....
    By 98L36 in forum Audio, Security & Visual Electronics
    Last Post: 08-01-2011, 04:59 PM
  4. sedan GTP front speaker question.
    By Dragonblaze in forum Audio, Security & Visual Electronics
    Last Post: 10-15-2010, 11:01 PM
  5. speaker and head unit question
    By biggmman in forum Audio, Security & Visual Electronics
    Last Post: 10-06-2008, 09:18 PM
