Thread: battery wire
Results 1 to 11 of 11
  1. #1 battery wire
    Vail, CO
    went for a 5 min drive. got out, got back in and car had 0 power. shook the positive wire around a bit then the power returned
    how do i fix this? get new wires? new battery?
  2. #2 Re: battery wire
    Clean them up and make sure they are tight.
    If any further problems after that, you might have to replace.
  3. #3 Re: battery wire
    Antioch, IL
    id strip the wire back to new copper and install new terminals. Had to do that on my truck
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: battery wire
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    clean the terminals on the battery good to go
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  5. #5 Re: battery wire
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    How old is the cable? Have you had a battery go bad and corrode? Often times the acid will get inside the insulation and corrode the wire, but it is not visible. The strands will break, but you won't see it unless you peel the insulation back. Typically, if I have a battery fail and leak acid on the cable, I just replace the cable to avoid potential problems down the road.
  6. #6 Re: battery wire
    If the bolt is loose (likely it is now) clean the cables and tighten them down. Keep in mind you are going into lead. It's not super strong like steel.
  7. #7 Re: battery wire
    Vail, CO
    the cables are probably as old as the car. i bought the car last year, and according to the receipt, the battery is a little over 1 year old. however there is white residue on the terminals which looks like there is corrosion. i think im going to have the battery and wires replaced because popping the hood to pull the cable to start the car is ghetto as hell. the alternator is brand new and i dont want to go fuking it up with a corroded battery
  8. #8 Re: battery wire
    Would it be easier to start by using an 8mm to unhook them both and clean them, then snug them up?
  9. #9 Re: battery wire
    Vail, CO
    i suppose you're right. so the terminals are the little horns sticking on top of the battery? do i clean them with a wire brush and some water with baking soda or something?
  10. #10 Re: battery wire
    Arizona
    If you can snug the terminals put a paper clip in between then tighten them down
  11. #11 Re: battery wire
    Nov 2011
    NY
    Quote Originally Posted by 91parkave View Post
    Good fix to get you home, but by no means is this a viable permanent solution. You're putting amperage through an 1/8th inch piece of junk metal... Lol
    Anyways, as noted, clean and tighten are first steps. If problems continue afterwards then you'll need to isolate the problem by checking all connections, grounds and such at the battery and alt and frame.
    Good luck!
  1. Looking for some speaker wire and a new ground wire.
    By Bluemagic in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 08:41 PM
  2. How to wire grand prix 97-03 amplifier to the battery?
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 09-01-2012, 06:39 PM
  3. battery wire???
    By kidscar2004 in forum General Tech Discussion
    Last Post: 07-09-2012, 06:45 AM
  4. Trying to tun my power wire to the battery
    By Zak97GT in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2011, 08:37 AM
  5. Power wire amp to battery
    By yeacashgpgt2002 in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2010, 11:45 AM
