Thread: New headunit sounds like ****?
Results 1 to 19 of 19
  1. #1 New headunit sounds like ****?
    gardner,mass
    So i went out to bestbuy today and got the gmos-04 wiring harness to hook up a new hu. Then i went and got a brand new kenwood kdc-152 from my work for cheap, only 62 bucks. Well its all hooked up and for one the volume only goes to 35, hardly pushing over my 12" aq in the trunk and is distorted as **** on radio and cd. I didnt solder but i never have befor. So is it the deck, my lack of soldering, or is there a way i can turn up the monsoon amp. With my 6 disc in there it easily could be heard crisp and clear over my sub.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
    Typical I had that same issue when I upgraded from the Monsoon keeping the stock speakers and up gutting everything out and going aftermarket. I would still check your soldering making sure everything is soldered tight and did you happen to try the HU out prior to buying it ?
    04 Comp G.
  3. #3 Re: New headunit sounds like ****?
    gardner,mass
    the hu i got brand new in the box so no i didnt
    also what i meant was i did not solder it cus i never have had to solder a hu befor and ive never had problems
  4. #4 Re: New headunit sounds like ****?
    gardner,mass
    thinking maby i should return the kenwood and grab a pioneer. Ive always have has good luck with pioneer
  5. #5 Re: New headunit sounds like ****?
    Oct 2011
    Oak Grove MN
    I have a pioneer in my 07 with the monsoon system and it sounds just fine. I would try soldering the connections and see if that helps.
    As long as you crimped it good I wouldn't worry about it.
    Pioneer > kenwood had nothing but positive things with my pioneer headunits also I'm a fan of alpine.
    04 Comp G.
  7. #7 Re: New headunit sounds like ****?
    When Cole ole buddy... What is the output of the stock HU in ohms? IIRC aren't monsoon speakers 1 ohm and you are correct, I don't know as much about car stereo as I do mechanical ...therefore I may be totally off base here. Maybe... it's unhappy with either the level outputs or the ohms.
  8. #8 Re: New headunit sounds like ****?
    Yoga city
    1ohm sounds low, if i remeber when i put my crossover on the stocks speaker i got a reading of 2ohm, so most like 4 ohm speakers, this was front, didtn check the rears they where just replaced. But i still dont think it would matter because of amp after the deck. The deck doest really push anything but a signal. i would say your clipping your stockers to death. check HU setting
  9. #9 Re: New headunit sounds like ****?
    GTP Level Member simbah's Avatar
    Lala land
    there is a gain adjustment on the GMOS-04, trying adjusting it till it sounds better. 2 adjustment pots on the black box, one is for the volume of the chimes and the other to adjust the gain for the system.But you will prolly eventually just want to trash the monsoon amp in favor of an aftermarket amp for better quality sound.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  10. #10 Re: New headunit sounds like ****?
    gardner,mass
    Quote Originally Posted by simbah View Post
    Thankyou this is what i was looking for, i thought it was only for chimes.
  11. #11 Re: New headunit sounds like ****?
    Yoga city
    didnt even think of the gain on there, good play sir
  12. #12 Re: New headunit sounds like ****?
    Jan 2013
    Tolono IL
    its the kenwood lol i have the same one...
  13. #13 Re: New headunit sounds like ****?
    gardner,mass
    Quote Originally Posted by lilmidge12 View Post
    your not trolling? does it really just sound like ****? cus ima return it and buy something else if so
  14. #14 Re: New headunit sounds like ****?
    Jan 2013
    Tolono IL
    no im serious...i hate mine..im getting a different one here soon
  15. #15 Re: New headunit sounds like ****?
    gardner,mass
    thankyou ima return it then
  16. #16 Re: New headunit sounds like ****?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Quote Originally Posted by Coleslaw View Post
    Also remember you get what you pay for. Buy another junk $70 Hu its not going to sound or last like a $200 one. Personally I paid 270 for my HU..... Try to get at less 4V pre outputs
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  17. #17 Re: New headunit sounds like ****?
    SWPA
    You are trying to push a sub with just a headunit and no amp (other than the monsoon)? Thats part of your problem.
    Quote Originally Posted by 1LoudGrandPrix View Post
    This times a million. You definitely get what you pay for in headunits. A good unit will run you $200 minimum. If you want a touchscreen with DVD and or nav expect to pay $500 minimum.
  18. #18 Re: New headunit sounds like ****?
    GT Level Member maverickdog8's Avatar
    Bettendorf, Iowa
    $500 minimum on a good flipout is a tad off. $350-$400 minimum for a good one new is more along the right track. I picked up my clarion VZ401 2 ish years ago new and love it.
    Doesn't skip at high volumes with my system and I can watch movies when we are on road trips.
  19. #19 Re: New headunit sounds like ****?
    SE Level Member timreams's Avatar
    Aug 2011
    Southwest of Pittsburgh
    300-400 for a flip out is accurate, 500+ is accurate for a DD touchscreen.
  1. Help on a headunit
    By jakeb157 in forum Audio, Security & Visual Electronics
    Last Post: 05-23-2012, 11:39 PM
  2. Headunit
    By EJRJR91 in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2011, 09:41 PM
  3. Well had to get a new headunit what do you think?
    By JoshsGTP in forum Audio, Security & Visual Electronics
    Last Post: 11-07-2010, 05:51 PM
  4. 05 GTP Headunit that bad?
    By OoteR in forum Audio, Security & Visual Electronics
    Last Post: 02-16-2010, 10:39 PM
  5. 04+ headunit in a 97-03 gp?
    By shawn3091 in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2010, 05:23 PM
