Thread: Daytime lights, driver info center, and heater blower motor
Results 1 to 9 of 9
  1. #1 Daytime lights, driver info center, and heater blower motor
    Jan 2013
    Warsaw Indiana
    I'm having problems with my heater blower and headlamps along with my driver info center. When I have the heater selector off everything works fine. But on numbers 1-4 the heat won't blow, daytime lights turn off and info center goes out. On 5 everything comes back on. I just recently changed the resistor a few moths back and haven't had any problems since then. Last night I just left the heater on 3 for about 10 minutes and it all came back on and seemed to fix its self.. Until I got in it this morning then the problem came back
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Hey dildo ..
    When I get off let's try the alternator I was talking to a guy and it sounds like it could be a voltage regulated problem.
    Considering you swapped resisters and checked grounds already .
    Bump / anyone else have any ideas ??
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  3. #3 Re: Daytime lights, driver info center, and heater blower motor
    GT Level Member GMCustomerService's Avatar
    Michigan
    Dilloncole17,
    I’m sorry you are experiencing this issue with your vehicle. Would you please PM me your VIN, so I may check my resources for any known issues?
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  4. #4 Re: Daytime lights, driver info center, and heater blower motor
    Dec 2008
    Lawndale, CA
    Sounds like the ignition switch is going out.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Quote Originally Posted by The Guz View Post
    X2
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  6. #6 Re: Daytime lights, driver info center, and heater blower motor
    Banned
    Jan 2013
    Colorado
    Quote Originally Posted by GMCustomerService View Post
    Dilloncole17,
    Louis
    GM Customer Service
    Why can't you just look up known issues for pontiac grand prix's? What benefit does him giving you his vin gain?
  7. #7 Re: Daytime lights, driver info center, and heater blower motor
    Michigan
    camopaint0707,
    I asked for his VIN so I could check for any possible recalls, which are VIN specific. In addition, he did not state the year of the vehicle, nor was it listed in his profile. Asking for the VIN would provide both.
    Louis
    GM Customer Service
    Warsaw indiana
    His car is a 97 gp gt with a l67 + hd trans swap . . It has the Manuel air
  9. #9 Re: Daytime lights, driver info center, and heater blower motor
    Fort Wayne, IN
    Yep it sounds like the ignition switch. I wired a relay to bypass it. The tutorial was in a different forum. I've not had a problem since I installed it.
    EDIT: I found the site for the relay I installed... http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
  1. 04 Grand Prix heater blower motor
    By srwa in forum General Tech Discussion
    Last Post: 12-26-2012, 10:28 AM
  2. DIC (Driver Info Center) Back lighting dim on one side?
    By Capt Fiero in forum General Grand Prix Discussion
    Last Post: 06-02-2012, 03:22 AM
  3. Driver Information Center - No lights, Any suggestions??...Please help
    By Tea Time in forum General Tech Discussion
    Last Post: 06-17-2011, 08:04 PM
  4. Fixed! blower motor, flashing headlights and dim information center
    By Mizzouri in forum General Tech Discussion
    Last Post: 10-02-2008, 02:37 PM
