Thread: Quick DVC Sub Wiring Question
Results 1 to 13 of 13
  1. #1 Quick DVC Sub Wiring Question
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    hey guys i got a quick question i just want to make sure im wiring my subs correctly i feel as if its a pretty simple question... ive never owned DVC subs before on SVC so i know the wiring is a little different and im trying to achieve a 1 ohm load
    i have dual 12" Pioneer TS-W309D4 DVC 4ohm 400w RMS
    running off of a Hifonics Brutus BRZ1200.1D it runs 1200 watts x 1ch at 1 ohm
    and while im at it guys... to properly tune the amp i will want to use a 50hz tone and then use this equation
    Voltage = sqrt(800W X 1 ohms)
    Voltage = 28.28427... V
    then i just use the dmm and im set right??
    video explains my question
  2. #2 Re: Quick DVC Sub Wiring Question
    GTP Level Member simbah's Avatar
    Lala land
    Two 4 ohm coils wired in parallel will equal 2 ohms, with that said if you wire both subs in parallel with each other than that load will equal 1 ohm. The reason you are not seeing the proper ohm reading is that it is a coil and your are actually reading impedence and not resistance. Your DVM is meant to read resistance and not impedence. So therefor 3.4 is actually considered 4 and 1.7 is considered 2. I hope I am clear enough, I am not an engineer, but if you were to ask one why then they would have a better explanation
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: Quick DVC Sub Wiring Question
    Nov 2011
    Decatur
    No actually that cleared things up a lot thank you!
  4. #4 Re: Quick DVC Sub Wiring Question
    Lala land
    here is a wiring diagram for you to reference
    http://m.seimg.net/product/img/subwo...variation2.jpg
    Also when wiring to your amp use the right speaker + and the left speaker - only, DO NOT use both sets of connections
  5. #5 Re: Quick DVC Sub Wiring Question
    Yoga city
    you will want all your bass, treble sub setting on teh deck at 0 when doing this. and make sure you have the correct 50 hz tone.
  6. #6 Re: Quick DVC Sub Wiring Question
    Nov 2011
    Decatur
    simbah - can use both because my amp provides 4 speaker connectors and wires them in parallel so i dont have to
    jteske- i used the 50hz tone here..? didnt know their was a difference
    Realm of Excursion
  7. #7 Re: Quick DVC Sub Wiring Question
    Lala land
    I mentioned that only because that's the way it was done according to the Hifonics Brutus owners manual on the Hifonics website.
  8. #8 Re: Quick DVC Sub Wiring Question
    Nov 2011
    Decatur
    It said to only use two of the connectors? Why would it give you 4 then?
  9. #9 Re: Quick DVC Sub Wiring Question
    Lala land
  10. #10 Re: Quick DVC Sub Wiring Question
    Nov 2011
    Decatur
    I have the brz1200.1d not a bre elite model
  11. #11 Re: Quick DVC Sub Wiring Question
    Lala land
    should be the same regardless. Same manufacturer. Doesn't hurt to try, hell you may even stop your overheat problem in the process.
  12. #12 Re: Quick DVC Sub Wiring Question
    Nov 2011
    Decatur
    I already stopped that problem a while ago I had a bad ground and the level was set too high... Not to mention bass boost constantly maxed on the HU
  13. #13 Re: Quick DVC Sub Wiring Question
    Nov 2011
    Decatur
    I believe I see where you see that about connections and that's for their 2 channel and 4 channel amps but if you look at the set up for dual subs on the mono amp it show all 4 connectors being used
  1. quick question
    By joe0813 in forum General Tech Discussion
    Last Post: 12-23-2012, 08:39 PM
  2. Quick Question
    By Matthew Mericle in forum Introductions/Noob Questions
    Last Post: 10-28-2012, 11:57 PM
  3. Quick question with wiring...
    By BCUZ RACECAR in forum General Tech Discussion
    Last Post: 09-20-2012, 02:30 PM
  4. Quick help please! Just a quick question!
    By nikkigpgt00 in forum Tires & Wheels
    Last Post: 07-31-2012, 12:29 PM
  5. Going to 3.4. Quick question.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2009, 01:50 AM
