Thread: Trunk Lighting????
Results 1 to 19 of 19
  1. #1 Trunk Lighting????
    GTX Level Member nikkigpgt00's Avatar
    MI
    Is it just me or does my 2000 GT not have a light in the trunk??? If so I cant find the darn thing! Its really dark and I need some light. Help!!!
  2. #2 Re: Trunk Lighting????
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    my 03 has one like right under the third light in the trunk. i hope that helps you find it your bulb probably burnt out. another one that gets me is that there isnt one under the hood. makes absolutely no sense to me
    silver 2003 Grand Prix GT List is on it's way to be updated
  3. #3 Re: Trunk Lighting????
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    ya, its there, unless sombody removed it, it should be right in the middle look up just after the trunk lid.
  4. #4 Re: Trunk Lighting????
    Ocala, FL
    I looked all in my trunk and couldn't find a/the light, and it ended up being burnt out once I finally found it..
  5. #5 Re: Trunk Lighting????
    West Side Michigan
    I don't have one at all.. I looked.. I think the owner before me did something stupid like get rid of it.. nothing like some LED strips to light your trunk up! If only I could find the wires that give power to the light...
  6. #6 Re: Trunk Lighting????
    Willoughby, Ohio
    you could just run wire from the fuse box back and put a switch in. and yea i have a neon back there right now because the housing for the truck light was broke when i got the car, so my trunck lights up red. i feel cool when i pop it at night to light up the cardboard box full of tools and jumper cables and books ha
  7. #7 Re: Trunk Lighting????
    If you find it, those LED bulbs from diode dynamics are supposed to be decent.
  8. #8 Re: Trunk Lighting????
    West Side Michigan
    Yea.. I don't wanna switch, I want the wires that activate power when the trunk is open, that way they turn on and off without me having to.
  9. #9 Re: Trunk Lighting????
    Charles City, IA
    Quote Originally Posted by nawarkk View Post
    Just wire it to an ignition hot source. They will be on when the key is on off when the key is off.
    SMGPFC Two Nipple General
  10. #10 Re: Trunk Lighting????
    Willoughby, Ohio
    ^^^good call, that way it wont drain your battery overnight or anything
  11. #11 Re: Trunk Lighting????
    GT Level Member MrPhotographer06's Avatar
    Fort Bragg, NC
    if you have subs, you could T it off your remote wire for your amp.. its run to a switched ign source.
  12. #12 Re: Trunk Lighting????
    Quote Originally Posted by MrPhotographer06 View Post
    I wouldnt do that.
    Most people go to relays for that circuit after 2-3 amps.
  13. #13 Re: Trunk Lighting????
    Fort Bragg, NC
    I wouldnt do that.
    i've always gone to the back of the radio.
    hmm. thanks!
  14. #14 Re: Trunk Lighting????
    Dem *****es flicker like a MOTHER****ER.
  15. #15 Re: Trunk Lighting????
    Windsor (ON) Canada
    Dollar Store, 6" tap light bar with 5 tiny bright ass bulbs, stuck it up near the third brake light, you cant see it unless you crawl in my trunk....works perfect
  16. #16 Re: Trunk Lighting????
    Donating Users smitz327's Avatar
    Oct 2012
    Illinois
    Found my light and changed it because it was burnt out but be very careful. Mine has a problem where the light stays on all the time and ran my battery down twice. First time I thought I had a bad battery and replaced for 120.00 then I finally wised up. Not sure what caused the light to stay on because I don't see a switch so I left it out. Someone said something about a magnetic switch but don't know anything about that
  17. #17 Re: Trunk Lighting????
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by nikkigpgt00 View Post
    Locating the trunk light: Trunk_Light
    Deleting said light and going LED: LED_Trunk
    smitz327, not sure how the trunk light can stay on, as the BCM shuts if off after 2-3 minutes (a pain when unloading a trunk full of stuff at night). There is a switch on the trunk lid that tells the BCM when the lid is closed. I had an issue where mine would not come on because the wiring on the lid was loose and the switch wasn't signalling the BCM.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #18 Re: Trunk Lighting????
    Nov 2011
    NY
    I spliced a small led light bar to the truck light source, works great and the bar throws lights everywhere. If I get a chance I'll do some pics.
  19. #19 Re: Trunk Lighting????
    Oct 2012
    Illinois
    I found the switch, it is right on the latch. I tested it with the light in and it seems to work. I even shut the trunk and checked through the back seat and it works. Haven't left it on the timer to see if it goes out yet. Funny because when I trying to figure it out before, it was staying on. Maybe water got in the switch or something before
  1. where to buy aftermarket lighting
    By jersey jok3r in forum Visual/Body Modifications
    Last Post: 03-15-2010, 02:13 PM
  2. How to change interior lighting
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 02-26-2010, 12:16 PM
  3. LIGHTING for an 04 GTP
    By ne04gtp in forum Shops and Community Heroes
    Last Post: 02-05-2010, 05:49 PM
  4. Lighting issues (again)
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2009, 07:03 AM
  5. Switch for neon lighting??
    By Grandprixse97 in forum Audio, Security & Visual Electronics
    Last Post: 02-02-2009, 09:55 PM
