Thread: bypassing factory amp?
Results 1 to 12 of 12
  1. #1 bypassing factory amp?
    Dec 2012
    Hamilton,Ontario
    I own a 1997 gtp with the 8 speaker premium, non-bose system. So after a few weeks of messing around I recently replaced the door speakers for 6.5" pioneers and blaupunkt 6x9's in the rear, didn't touch the 4's. But, turns out there's no sound going to the 6x9's at all! My question is about the little amp/booster behind the glove box: does it power all speakers or just the 6x9's? Tried researching with no clear answer. I'm planning on putting in a aftermarket HU later, will I have to bypass the amp/booster anyways? If so I'd like to use the stock 6x9 wiring from the amp/booster to wire the aftermarket HU.
  2. #2 Re: bypassing factory amp?
    Dec 2012
    Hamilton,Ontario
    wow, no one here has ever replaced their stock head unit with an aftermarket one?
  3. #3 Re: bypassing factory amp?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Quote Originally Posted by Adasm View Post
    Relax...
    Unhook the 4s, the new 6x9 you got will be better than the stock 6x9 and 4s together.
  4. #4 Re: bypassing factory amp?
    Just unhook the 4" and run the 6x9s you will never notice them not being hooked up.
    And just FYI this has been asked quite a few times already. Just saying.
  5. #5 Re: bypassing factory amp?
    Dec 2012
    Hamilton,Ontario
    Quote Originally Posted by slick2500 View Post
    See, i have been looking and have been unable to find an answer. I'm not concerned with unhooking the 4" speakers, I was just asking if I had to bypass the amp after hooking up an aftermarket HU. I've read that some people have but the majority of other people dont even mention it.
    With this amp, I do believe the 6x9's receive a different signal than the 4" speakers, hence the reason for the low frequency factory amp.
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    Just unplug it! That's what I did to mine I had all kinds of sound problems with my alpine HU and 6x9s unplugged the factory amp problem solved
    Don't over complicate things...just unplug it..should work just fine!
    04 Comp G.
  8. #8 Re: bypassing factory amp?
    Dec 2012
    Hamilton,Ontario
    Thats exactly what i'm trying to do, complications aren't my thing! lol! I do want to unplug that amp, i was just wondering if it's only purpose was to power the 6x9's or if it powers all speakers. If it does all speakers, then that means running all speakers directly from the head unit.
    Jul 2012
    Kansas city
    No unplug it and all speakers will work just fine mine is unplugged and I did no wiring except the head unit install. Unplug it its under the glove box no problems all will work
  10. #10 Re: bypassing factory amp?
    Dec 2012
    Hamilton,Ontario
    Thanks, I'm gonna unplug that amp today and go from there, thanks everybody for the input. I am by nature an impatient person, mind me if I seem so, I don't mean to be rude.
  11. #11 Re: bypassing factory amp?
    Dec 2012
    Hamilton,Ontario
    So, unplugged the amp and nothing changed. All speakers still functioned the same except for the 6x9's. Phoned an audio shop that I was referred to and an installer there also told me that the little amp is only for the 6x9's. I inspected my amp and found that the board was severely corroded due to a leak that is apparently common from the firewall and shorts out these little bastards. So, now I just have to decode the wires and find out which ones run back to the 6x9's and wire them back up!
  12. #12 Re: bypassing factory amp?
    GT Level Member atj8's Avatar
    Midwest
    the amp is primarley used to power the 6x9s...theyre used more for bass...just hook up an amp to ur 6x9s and leave the 4" plugged..call it a day. wrks fine for me.
  1. Factory Air Dam.
    By Logan541 in forum How To Write-Ups/Tech Tips
    Last Post: 06-29-2012, 08:21 PM
  2. anyone know where the factory amp is in a 01 gp-gt??
    By trumanshow in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2012, 02:42 AM
  3. bypassing Bose amp
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 02-04-2009, 11:51 PM
  4. belt help, bypassing power steering pump
    By skates in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2008, 11:24 AM
