Thread: 4ch Amp Cutting In and Out
Results 1 to 16 of 16
  1. #1 4ch Amp Cutting In and Out
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    Alrigh guys so I bought a kenwood 4 ch amp on cyber Monday... The one some of you guy suggested to me and I feel like the cold might be affecting it... Because I installed it shortly after getting it and it worked beautifully and then more recently it's gotten colder outside and it started cutting in and out and then now it's not playing at all most of the time leaving me music less .. I also have started hearing more engine noise through my rcas and I tried differentent rcas and that's not the problem
    SE Level Member Peirce1970's Avatar
    Myrtle beach, S.C.
    If your hearing engine noise you could have a bad ground.
  3. #3 Re: Amp actin weird
    Nov 2011
    Decatur
    Like engine noise through the speakers? It's a high pitch noise and gets louder as I accelerate
    It's still not all that loud though I never noticed it when the amp was working properly...
    Could it also be bad rcas or no?
  4. #4 Re: Amp actin weird
    Nov 2009
    illinois
    alt. whine.
    try grounding your amp to a different spot.
  5. #5 Re: Amp actin weird
    Nov 2011
    Decatur
    Is "bad ground" also the reason it cuts completely out and doesn't even work sometimes? Sometimes it even works but when I turn up the volume like one click it goes off again
  6. #6 Re: Amp actin weird
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    Ground loop is the factor hear!
  7. #7 Re: Amp actin weird
    Nov 2009
    illinois
    yeah its a ground problem. Well im assuming your running proper sized power/ground wire.
  8. #8 Re: Amp actin weird
    Nov 2011
    Decatur
    It should be big enough I mean it's a cheap 4 gauge so more like 6-8gauge but the amps only like 400 watts... The thing is that it was working perfectly earlier
  9. #9 Re: 4ch Amp Cutting In and Out
    Nov 2011
    Decatur
    It wouldn't be by chance a blown pico fuse would it? How can you check if you're pico fuse is blown?
    Sep 2011
    Arkansas
    Might be the pico, but I've never heard of it causing intermittent functioning... just whine. Dunno how to check it, but the fix is easy enough... ground the rcas to the radio chassis. I'm assuming you know this since you mentioned the Pico fuse in the first place. I'd redo the ground and do the Pico fix to start personally.
    Sent from my A200 using Tapatalk HD
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  11. #11 Re: 4ch Amp Cutting In and Out
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Where did you ground it to?
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  12. #12 Re: 4ch Amp Cutting In and Out
    Cleveland Heights, Ohio, United States
    Ground, and noise can come from power wire and your RCA's being to close. Do you have matching Ground and Power wire gauge?
    1998 Pontiac Grand Prix GT
    1998 Pontiac Grand Prix GTP
    2008 Buick Lacrosse Super
  13. #13 Re: 4ch Amp Cutting In and Out
    Nov 2011
    Decatur
    this isnt the amp i am having problems with (anymore) but at about the 3 minute mark you can see how i grounded my other one as well... i didnt use the same screw i just drilled another one but its like a foot from the other ground on that same frame
  14. #14 Re: 4ch Amp Cutting In and Out
    Nov 2011
    Decatur
    well i finally got the chance to investigate the problem with it being basketball season...
    what i found was that the screw i used to ground it had come loose some how causing the intermitent problem so i used a different screw and its a lot tighter now and fixed the intermitent problem but i am still hearing the engine whine (i have it grounded basically the same place i grounded my sub amp which is to the chasis under the back seat but the engine whine still occurs... i have not tried to fix it by grounding the rca's yet i might try that today but the rcas and power wire are ran on opposite sides of the car
  15. #15 Re: 4ch Amp Cutting In and Out
    GTP Level Member simbah's Avatar
    Lala land
    Do yourself a huge favor and ground your amps to a strut mount mounting bolt anduse a star washer under the lug and a flat wasner under the nut and make sure that they are tight and you should eliminate a lot of your problems. Yes I would put spacers under the amp so you get some air flow all around the amp, should help with cooling.
    The following was taken directly from Hifonics Website
    It is highly recommended that the amplifier be mounted to a board of MDF or other solid
    structure using the 4 mounting screws provided. Avoid mounting the
    amplifier to metal as this can introduce noise and other unwanted issues. When mounting
    the amplifier, ensure that it is mounted HORIZONTALLY, as shown in the diagram above, for
    optimal heat dissipation. Mounting amplifiers to speaker enclosures is not recommended as
    this can cause damage to the amplifier components.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  16. #16 Re: 4ch Amp Cutting In and Out
    Nov 2011
    Decatur
    that video is old... i dont really remember what i did to fix that problem but i fixed it a while back... and i havent had a problem with wiring it under the seat.. but i honestly dont know what or where a strut mount is...
    and i tried grounding out my rcas (as if i had a blown pico fuse) and it seems to have eliminated my alternator/engine whine so hopefully that will fix the problem for good
  1. This is weird
    By kjohnson in forum Forum Bugs/Suggestions
    Last Post: 06-08-2011, 04:12 PM
  2. Actin funny
    By kjohnson in forum Brakes/Suspension/Chassis
    Last Post: 06-05-2010, 07:57 PM
  3. weird....
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-24-2010, 12:30 AM
  4. rear speakers actin up
    By cooldave15 in forum Off Topic Discussion
    Last Post: 11-11-2009, 11:33 PM
  5. weird that my car is doing this!!!!!
    By lilredss0287 in forum Turbo
    Last Post: 12-05-2008, 04:59 AM
