Thread: Aftermarket 6x9s with factory monsoon amp
Results 1 to 5 of 5
  1. #1 Aftermarket 6x9s with factory monsoon amp
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    Just wondering if there is a way to run aftermarket 6x9s like how the monsoon 6x9s are with separate wires to the 6x9 and the mid. Since most 6x9s just take one set of wires. For some reason I'm having a tough time explaining right now ha but have my 6x9 power already supplied go to the aftermarket 6x9 and the mid power already supplied go to the aftermarket mid like the factory set up
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  2. #2 Re: Aftermarket 6x9s with factory monsoon amp
    Sep 2011
    Arkansas
    No clue. Honestly, if I (for some odd reason) kept the Monsoon system in that situation, I'd source out a 6x9 component set. Either that, or just grab some 6x9s and a set of tweeters. If you don't mind running some wire, it'd be a good chance to play with placing additional tweets up front, if that's your thing.
    Edit: Broham... GET THESE Audio Savings | Pair Cadence CVLW69 6x9 Competition Mid-Bass Driver Car Audio Midrange Speakers
    Add some tweets of your choice, and you should be able to knock the stock Monsoon stuff out of the water (depending on impendances.... not sure what Monsoon runs at).
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  3. #3 Re: Aftermarket 6x9s with factory monsoon amp
    Yoga city
    really all anybody needs to understand is one wire is for highs, one is for lows. most 6x9's will have two sets of wires running to one terminal. seperate and hook up accordinly and it will be just how it is from the factory
  4. #4 Re: Aftermarket 6x9s with factory monsoon amp
    Apr 2011
    Fargo
    Yeah so I got some polk 6x9s and they didn't have a good way at all to connect separately.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Quote Originally Posted by JTeske88 View Post
    X2
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. 2006 Monsoon system- dead 6x9s
    By MSUvball14 in forum Audio, Security & Visual Electronics
    Last Post: 05-15-2012, 11:20 PM
  2. 12v remote factory 2005 monsoon
    By 05gtpcompG in forum Audio, Security & Visual Electronics
    Last Post: 06-18-2011, 02:50 AM
  3. Adding Factory XM to Monsoon MP3 Player
    By copperbird in forum Audio, Security & Visual Electronics
    Last Post: 11-11-2010, 04:02 PM
  4. '06 Factory Monsoon Radio INOP
    By CaptLively in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2010, 07:39 AM
